Working on an early 2000s dell / harman kardon computer speakers.
Suddenly only the right speaker works. No sound is coming out of the left. Also, the right is much louder than when both speakers were working. The minimum volume setting sounds much louder than where I previously set it (half way). And the loudness difference between minimum and maximum position on the knob is small compared to when both were working.
I checked the signal wire for continuity from the board to the jack. Both channels and the ground are continuous with low resistance and not shorted together. I am suspecting the amplifier ICs. TDA1517P and LM324N
Is there anyway to rule out the other components like the volume potentiometer or a bad cap? Or maybe dianose if only one IC is bad and which one it is? There is nothing obvious on the board.
