Hi all, This is my Coffee maker main board. Last week there was an electrical surge & it blew out the fuse and this 2 watt resistor. Can anyone figure out the value of the resistor. It on the AC line, hope someone can help view this attached photo or if anyone has this schematics. Thanks in advance.
Burnt Resistor Value
Re: Burnt Resistor Value
Thanks for the reply.. If you see the photo close, before the resistor there was a thermistor which was burnt too, this was shorting the AC lines, once replaced the short was 100% gone & there are no shorts further on in the circuit. Now it's only the resistor value I need to know to repair this board. If anyone can help me finding this Value, by the shape I know it's 2 watt. Thanks
You won't get a reading ACROSS the resistor you will need to clean part of the exposed wire to get any reading, This value should be close to half the original value. You could also provide a clear picture of the trace side, maybe we can figure out a close value.Last edited by R_J; 11-29-2022, 08:36 PM.
