need schematic DELL N4030 DJ1 CP Discrete 09259-2 48.4EK01.021
    Hi to all
    need schematic DELL N4030 DJ1 CP Discrete 09259-2 48.4EK01.021.
    tnx
    Re: need schematic DELL N4030 DJ1 CP Discrete 09259-2 48.4EK01.021
    hello
    help please
      Here you go:
        tnx friend
        but i can not find N4030 Battery Connection DC Jack USB WLAN Wireless Board schematic there (DAUGHTERBOARD)!!!!
        part number:48.4ek20.011
          Sub board only can see on BV (boardview-IOBD2-2), the schematic have many blank page
            laptop working fine with battery but not turn on by adapter.i need DAUGHTER BOARD schematic .
              Not available, that' way I've upload with BV.
              Check first mosfet and resistor divider which connected with that gate. (PU201)
                tnx
                i have 2.8 v in pu201 pin 4(gate).pu201 is ok.and i can not find resistor divider?
                  So, the BV doesn't help you, then its time to make your own schematic with following the BV.
                  taken from HM40-MV, here for example:
                  if follow from schematic HM40, resistor for voltage divider are R1 200K and R2 100K then result 6.3V, so on gate PU201 should be 6.3V. Have no idea if only 2.8V on that gate can make 19V from S crossing to D.
                    thank you very much my friend for your help.
                    after replacing charging IC (BQ24745)problem solved.
                    tnx again brother
                        thanks your help meritosari
                          thanks your help
                            Thankszzzz
