SONOS Play 1 no power burnt out component
    I need to replace this burnt out component but don't know what it is. Can anyone help identify it please? It's on the underside of the board.
    2 pictures, one full board, one closeup:
    Re: SONOS Play 1 no power burnt out component
    Fan6751, The is will likely drive a mosfet on the other side and it will also be blown
      In addition to the microcircuit, the R178 resistor burned out, and rather something else, you need to ring its entire harness.
        Check your main filter capacitor too. If it's bad, that could be why the MOSFET blew to begin with. The MOSFET snubber network is also suspect.
        I would also check diodes etc around the FAN6751, some may be shorted from the same voltage spike that blew it.
        -David VanHorn
          hi guys .
          can you help please . i need value of R178
          thanks
            Hi, R178 measures 148Ohms (in circuit)
