Re: Fish Tank LED Power Supply Gets Hot then shuts down
OK, some interesting new knowledge ...
When the other two fan ports wouldn't lite up the fans, I suspected that maybe it had something to do with the thermistor mounted above the MC and I tried warming it up but no luck... so I decided to see what this board does with the LCD screen attached to it so I pulled it out of the chassis and connected it.
When it boots, it says that it is Jan 1, 1980, and that it was 80 degrees ... so I then connected the other fan to the nonworking port and when I heated the thermistor this time, it kicked on the other ports.
There are two fans on each end of the unit, and they are mounted so that one side blows air into the unit and the other side blows air out so I'm sure that they connect it so that only two fans are moving air until it gets too hot then it kicks on the other set ... and it also kicks up the fans that were running so that they run faster.
When I was done testing, I cut power and felt the heat sink on the 7805 and it was TOO HOT TO TOUCH
Any thoughts on that? It's just a 7805, and I have a bunch of those with new heat sinks should I replace it?
Current draw was only half an amp on the 12 volt bench supply. So the 7805 is powering the MC, and the LCD screen but the fans are sourced from +12 outside of the 7805 and they take about 140ma each and I had three of them running so the 7805 was technically only taxing the power supply with less than 200ma and it got that hot.
