12v 1uo941243c Relay repairable?
    Re: 12v 1uo941243c Relay repairable?
    Most likely under the hood near the battery
    And a number will be on the top of the fuse or on one side of the fuse
    They will not look like the lower amp fuses
    I just got done installing a car stereo in a semi truck that the engineers thought it was cute to do all the speakers wire green including the power on all the time the ignition switch power the negative side was white
    This only took about an hour for me to figure what wires went to what speaker plus the negative and positive side of each speaker and what wire was power on and the ignition switch power supply with out a wiring diagram but I have many years of experience doing troubleshooting and having the skills that are needed
    9 PC LCD Monitor
    6 LCD Flat Screen TV
    1 Dell Mother Board
    15 Computer Power Supply
    All of these had CAPs POOF
      Originally posted by bohaboha View Post
      where are those high amps fuses location d int se any this week realy funny
      I think there is a cover on the battery, it's under that.
        Originally posted by sam_sam_sam View Post
        PN = negative side
        50 Z = is your control power
        50 A = is your positive side
        it is not that relay next black
        or brown then black that one thank you
          those are 30 amp and they are ok
            Check all of the high amp fuses there was a time way back when they used fuse able link instead of a high amp fuse this much hard to find because they can be any where in the car
            9 PC LCD Monitor
            1 Dell Mother Board
              cant remember if i posted pics of the fuse boxes . .. just starting up the laptop
                Post a picture of the relay that you want to know about
                9 PC LCD Monitor
                1 Dell Mother Board
                  yes post 41 there is no 50 amp on it
                    engine bay 1 .there are 8 fuses together .its one of those .
                    left side behind the headlight just to right of battery as yo look at it and behind battery
                      here it is
                        when quoting post numbers please add the link by right clicking on post number and copy link then post it .
                          ok if you cant find the fuse pull k20 and see if its getting power on one of the large terminals in the socket .
                            Three 30A ?, the bigger ones are the metal strips.
                              https://www.badcaps.net/forum/showpo...2&postcount=42
                                excuse me which socket do you mean ? can i use 2 cement10k ?
                                  you mean that in addition to the 30amp fuses those metal strips are those high amps fuses?
                                    just measure the voltage on the large terminals where k20 relay plugs in . one should be 12v . the other is going to be shorted to chassis if the fuses have been replaced that blew first .
                                      you need to find and fix the short before blowing more fuses .
                                        i did it allredy ut there i gott power from 2 pins and the fuses are replaced here somes pics. the car have an cautomatic gearbox
                                          any advancement ?
