Hi
SC board shorted on this one. It is TNPA4782 (AG).
I already tried once to repair it by changing shorted bits, but it gone short again right after power up. SC50 was jumpered, so none of buffer boards could kill it. Things i've replaced first time were: Q660,661,621,622,421,422,423,441,403. Also q551,702, ic773,464,465,d865. Obviously missed something first time.
So now the IGBT's that gone short are: Q401,402,403,421,422,423,621,622 and Q661.
R707 (3,9k) blown, q701 shorted, ic773, ic562.
Drivers ic501, and 502 look ok, but i will change them both. ic771 com to Vin resistance around 2k, com to Vout around 6k.
5V to gnd resistance is around 620k, and on 15V line resistance is 4.44k which is similar to someone's testing here on the forum (sry can't find the thread but i know i read that somwhere), so that looks promising.
I plan to replace IC561,562,563. IC501,521, Q501,502,521,522,531551.
And all before mentioned shorted things.
Double checked all resistors, just that one blown - R707. Also went through all small transistors, they do seem fine (diode check).
This is the schematic i've been using for throubleshooting: panasonic_tc-p46g15_chassis_gpf12du - can be found on elektrotanya if someone is interested to check it out.
Read at least three times the whole "rebuild tnpa 5081" thread and few similar, helped a lot, and also a lot similarities between all that boards.
So if someone have something to suggest or ask please do, i hope this time this board wouldn't go short again
thx
thx
