Hp LA-D711P motherboard Schematics
    HI all
    i need a hp 255 g5 bdl51 la-d711p rev3.0 shematics diagram
    thanks
    hp 255 g5 la-d711p schematic
    I need schematic of la-d711p
    Please help me sir
      Does any have the Schematics of this motherboard LA-D711P...I need this diagram if some one can help. Thanks
        Re: Hp LA-D711P motherboard Schematics
        Kindly help., anyone has this Schematics please., I just need it, I checked on the GPU VCORE coil I am only getting 0.29V, whereas the volts out here should be above 1volt., need to know what chip is producing the voltage for the GPU VCORE. Thank
          Re: hp 255 g5 schematic
          i want also schematic for la-d711p rev 1.0
            Hi guys. you need to know what kind of element
            burned out.
            La-d711p rev:3.0
              Pd1-vc06c
              pd2-vc06c
                Re: hp 255 g5 bdl51 la-d711p rev3.0
                bdl51 la-d711p rev 3.0 boardview V shematics diagram thanks
                  bdl51 la-d711p rev 3.0 wiring diagram, schematics etc, needed if possible please guys.. appreciated :-) wanting to locate some more info on an ic located at pu2.
                    PU2 is RT8243AZQW
                      Originally posted by mcplslg123 View Post
                      PU2 is RT8243AZQW
                      Sorry for late reply but thx ✌️
                        what is the integrated code in pum2 thank you in advance
                          my motherboard is hp 15 BDL51 LA-D711P REV 1.0
                            VC064 is the number printed on this part... its a dual diode
                                This
                                  Originally posted by skynet83 View Post
                                  This
                                  AOZ1336DI
                                    la-d711p schematics.....?
                                      Pd1 = pd2
                                        LA-D711P schematics please
