Mac mini 820-3228-b no power,Bios
    hi guys, i have this mac mini mainboard 820-3228-b that doesn't turn on,
    Primary power supply 12V ok
    3.3v is ok
    On the bios chip I have a variable voltage ranging from 0 to 3v constantly
    The bios chip is ok there are no schematics for this motherboard, I wanted to understand what can cause the voltage drop to the bios chip
    There are no shorts or burns on the motherboard, as the chipset carries the intel SLJ8C, can it be causing this voltage variation?
    or to try the flash to the bios chip with a different image?
    Re: Mac mini 820-3228-b no power,Bios
    hi.
    Place your meter in resistance mode, turn off / remove all power and then check the resistance to ground on all coils on your logic board.
    You may have a local bad / shorted capacitor that is causing a short circuit event due to the low internal resistance. This will force the local switching regulator to turn off or enter chirp mode (ON / OFF / ON cycling) to prevent damage.
    Post your results / pix if you find something that has a very low resistance to ground.
      Originally posted by mon2 View Post
      hi.
      thanks for the advice, I have a low resistance on the black coil, generated by this component, I do not know if it is a diode, I am attaching a photo of the faulty component,
      the red circles are low bga power supply resistances, they are correct
        ok, it's a capacitor, datasheet placed for those who need it,
        I'll post the results of the repair
          hi.
          1) with the power OFF, what is the resistance reading on this coil to ground ?
          2) with the power ON, what is the voltage reading on this coil to ground ?
          It is possible for a rail to have a low resistance to ground if the rail is a low voltage supply such as 1v0 or 1v05, etc.
          Just the same, if there is a bad cap on the rail, you can face a very low resistance to ground so please post the value you are reading on this coil. If the voltage reading is not normal then this rail is defective and could be linked to:
          a) bad cap - certainly you can try to remove this cap and then check the resistance to ground - if the resistance is higher then this cap is bad and needs to be replaced
          b) coil not soldered / solder cracks over time due to heavy currents through this rail - you can reflow with flux and hot air to resolder each such connection
          c) local mosfet is defective ( the square looking device with IR = international rectifier is the mosfet )
          Assuming there was no liquid damage to the logic board.
            hi.
            thanks for the advice, the capacitor was defective, the machine was repaired
              Good job!
                Hi, I have 2 units, both same problem. Replaced caps, checked for shorts, and plugged cable - cap goes bad again.
                Stumbled. Any insight would be great!
                  That caps are at 5V line so beware if you use 2,5V capacitors
                    Thanks for the tips and photos (reset1986) - helped me quickly find the shorted cap on my 2012 MacBook mini.
                      hello from france
                      I have the same failure on a mini mac of 2012 I7 2.3ghz
                      I had a 0.22ohm resistor between this coil and the ground I desoldered this capacitor and miracle the Mac starts
                      thanks for the information
