Thread Tools | Display Modes |
#1 |
City & State: Ames Iowa USA
Line Voltage: 120VAC 60Hz
![]() I have a motor control board I am trying to repair. I've been told the motor is fine, but the control board will only make the motor go one direction but not the other. Power comes in through a linear transformer and then a rectifier bridge and then filter caps. No schematics for the board. Relays on the board are 24V so I started by setting my bench PSU to 24V and injecting voltage. There are several LEDs. All but one LED lights up. There are test points labelled +15V, 0V and -15V. When checking voltage potential between +15V and 0V, I get a perfect 15V. For -15V to 0V, my meter shows approximately +1.15V. There are two voltage regulators with large heat sinks on the board. One gets warm, and the other is room temp. I think i will check for input to the cold voltage regulator next, but I'm trying to figure out why I'm getting the +1.15V reading on the -15V.
#2 |
City & State: Some times Sunny Jacksonville FL
My Country: USA
Line Voltage: 120 Volts 60 HZ
I'm a: Knowledge Seeker
![]() Post a picture of this device so we can see how this is made so we might be able to figure out what might be going on
__________________
9 PC LCD Monitor 6 LCD Flat Screen TV 30 Desk Top Switching Power Supply 10 Battery Charger Switching Power Supply for Power Tool 6 18v Lithium Battery Power Boards for Tool Battery Packs 1 XBox 360 Switching Power Supply and M Board 25 Servo Drives 220/460 3 Phase 6 De-soldering Station Switching Power Supply 1 Power Supply 1 Dell Mother Board 15 Computer Power Supply 1 HP Printer Supply & Control Board * lighting finished it * These two repairs where found with a ESR meter...> Temp at 50*F then at 90*F the ESR reading more than 10% 1 Over Head Crane Current Sensing Board ( VFD Failure Five Years Later ) 2 Hem Saw Computer Stack Board All of these had ![]() All of the mosfet that are taken out by bad caps ![]() |
#3 |
![]() Here's a picture. There's a second board on the bottom that's almost entirely diodes and transistors. I checked all those with a meter and they seem good. I'll get a picture of the bottom board if needed.
#4 | |
City & State: ☻
My Country: Canada
I'm a: Professional Tech
![]() What are the numbers on the regulator ic's? especially the negative one. Doe the transformer only have 2 wires supplying the board or is it center taped?
Quote:
If you don't have a balanced circuit +15 and -15, you could see some positive voltage on the negative supply. Last edited by R_J; 10-31-2021 at 03:21 PM.. |
#5 | |
![]() Quote:
on the board they are labelled AVR1 and AVR2. on the IC packages themselves, there is 3125p 6n27 on both. they seem to be identical, but only one is getting warm. The main transformer seems to have multiple taps. |
#6 |
City & State: ☻
My Country: Canada
![]() It's nice top know one is getting warm, it would be nicer to know WHICH ONE? I will guess and say the +15 is getting warm and the -15 is not.
If both components have the same numbers it is unlikely they are both positive and negative voltage regulators Do both regulator ic's have a common ground? have you checked the IN on the -15 ic to see if it has any voltage? The transformer secondary is likely center tapped and the center tap goes to ground, and one part of the winding supplies each ~ on the bridge rectifier, then the + of the bridge supplies the positive IN for the +15v regulator and the - of the bridge supplies the negative IN of the -15 volt regulator Last edited by R_J; 10-31-2021 at 04:53 PM.. |
#7 |
Solder Sloth
City & State: CO
My Country: USA
I'm a: Hobbyist Tech
![]() Odd both regulators are TO-3P and the board silkscreen says out-in(tab)-G which is typical for the negative rail regulator (should be in-G(tab)-out for positive). Make sure the "in" is the right voltage in any case.
These regulators are probably NOT for the motor but rather for the zillion op amps on the board that may control the motor drivers. |
#8 |
City & State: Alberta
My Country: Canada
![]() Either the -15V rail has wimped out and collapsed, or something is overloading the -15V regulator. It's not good for IC's and semi's power if a -ve rail goes +ve. I would put a reverse diode from each of the two rails to GND, to keep working on this.
The two VREG's look like on the main board two big heatsinks, the IC's are TOP-3 packaged, one says G/IN/OUT. The second board has a bunch of dual diodes and transistors, I don't see a voltage regulator in the line up. |
#9 |
My Country: USA
![]() What type of motor does this have and what components are on the second board other than the ones on the heat sink
#10 |
#11 |
#12 |
Solder Sloth
City & State: CO
My Country: USA
![]() photo of the tracks on the back side of the board? does not seem right that two apparently "GND" ports are not grounded/tied together - unless the company was playing tricks with virtual grounds and using the same BOM device for both rails... Or the silkscreen is wrong and the chips on the heatsink are different, still don't know what they are...
#13 |
![]() I'm going to check the linear input transformer by disconnecting it from the board and applying 120VAC to the primary windings and see what all the outputs are. If everything looks good there, I'll connect up the board to 120VAC through an isolation transformer and see what happens. Got to get the supply voltages worked out first before checking anything else.
I've gotten more information about the problem. The outputs for one motor work, but not for the other motor. The maintenance guy switched the non-working motor to the contacts for the working motor and the motor worked, so it's probably something in the output, although it might be a problem on the input side too. |
#14 | |
Leaking Member
City & State: Atlantic Canada
My Country: Canada
Line Voltage: Ground, 0Hz
![]() Quote:
#15 |
![]() I applied 120vac to the primary and here's I measured with green as ground:
grey one is 10V blue one is 40V purple is 2.25V yellow is 5V orange is .5V |
#16 |
City & State: ☻
My Country: Canada
![]() When you checked for the missing -15 volts, was that using the main transformer with 120vac applied or was it when you used your 24vdc bench power supply?
#17 |
![]() That was with the power supply. I finally got a chance to try the board in the machine and the input voltage was 107VAC.. not sure why it's 107V because that is just outside the typical 110-120VAC. Either way, in that case the -15V was also missing, and I was still getting about +1V on that rail, so my first task will be to get that figured out and repaired.
#18 |
City & State: ☻
My Country: Canada
![]() 107vac is likely that they have 3 phase power supplying the building and they use one phase to supply the board, this is normal.
Locate the source for the -15v, trace the -15volt point back, the ac for this circuit is likely supplied from the transformer and then through a diode or bridge to give a negative voltage. |
#19 | |
![]() Quote:
#20 |
Solder Sloth
City & State: CO
My Country: USA
![]() Black square thing with four pins on the corners, a hole in the center, and a notch cut from one corner is a bridge rectifier. Can't see the designator, need more pictures from different angles so we can tell what you're talking about.
Have to say it's highly irregular to have AVR1 and AVR2 in parallel, then again they being identical parts? What are the part numbers? Why does AVR1 look like it peeled from the heatsink? -- oh...so avr1 and avr2 are not parallel as the G pins are not connected, so one of them is being used strangely for bipolar supplies? Still a mystery what part numbers they are and how they're connected to the rest of the board... Last edited by eccerr0r; 11-12-2021 at 12:36 AM.. |
Thread Tools | |
Display Modes | |
