Old 01-15-2022, 01:15 PM   #1
StromarMiki
City & State: Brezice
My Country: Slovenija
Default philips 32pfl5507k/12
Hi, for philips i need service manual.
I have problem with power supplay DPS-98EP A
I change fuse and TK13A65U. But not have voltage 12V only 3.3V.
StromarMiki is offline   Reply With Quote
Old 01-16-2022, 08:56 AM   #2
dick_barton
dick_barton's Avatar
City & State: Cardiff
My Country: Wales
Line Voltage: 230V AC, 50Hz
I'm a: Hobbyist Tech
Default Re: philips 32pfl5507k/12
Have a look at
https://english.electronica-pt.com/e...=32PFL5507K/12
dick_barton is offline   Reply With Quote
Old 01-16-2022, 09:33 AM   #3
StromarMiki
I already found it. i have ERROR CODES - LED BLINKING CODES.
4s pause and 3 fast flashing led blinking. I can't find this error.
Old 01-16-2022, 01:27 PM   #4
dskall
dskall's Avatar
City & State: Bakersfield ca.
My Country: usa
Line Voltage: 120VAC 60Hz
Why do you need error codes if you know the problem?
dskall is offline   Reply With Quote
Old 01-17-2022, 08:31 AM   #5
StromarMiki
when connected to the power supply, red led blinking. (4s pause and 3 fast flashing led)
Voltage is only 3.3V.
Old 01-17-2022, 01:18 PM   #6
R_J
City & State: ☻
My Country: Canada
Where is TK13A65U in the circuit? is it in the standby, pfc or main circuit?
Usually when a mosfet like this shorts it opens the source resistor and can damage the drive ic as well.
R_J is offline   Reply With Quote
Old 01-17-2022, 02:28 PM   #7
StromarMiki
i can't find it in the service manual.
Old 01-17-2022, 03:41 PM   #8
R_J
City & State: ☻
My Country: Canada
The service manual does not have the dps-98ep schematic. That does look like the main mosfet that drives the main transformer. There is a resistor R611 0.24Ω (mosfet source) located beside that heatsink, check that it is not open, I expect that it is open. If R611 is open, check R610 as well, it connects the mosfet source to ic601'a CS pin.
Old 01-18-2022, 03:12 PM   #9
StromarMiki
I marked it wrong, TK13A65U is located on the second aluminum plate.
Old 01-18-2022, 04:16 PM   #10
R_J
City & State: ☻
My Country: Canada
What is its board location number? that looks to be a Diode (D120)?
Do you have any voltage across C700A or C120A? (I'm not sure of the numbers).
If it was indeed a mosfet I suspect it is used to switch a voltage
Old 01-23-2022, 11:53 AM   #11
StromarMiki
No voltage on c120 and mosfet.
The problem is on the primary of the transformer
IC 601 may not work. How can I check the operation of the transformer.
Old 01-23-2022, 12:08 PM   #12
R_J
City & State: ☻
My Country: Canada
Check R611 0.24 resistor and see if it is open What is the number on Q601 AND IC601?
Old 01-23-2022, 01:52 PM   #13
StromarMiki
R611 is good-closed, Q601 is good, ic601 2QS02G
Old 01-23-2022, 08:23 PM   #14
R_J
City & State: ☻
My Country: Canada
Do you have vcc voltage (20v) on pin7 of ic601? be careful not to short the ic pins. There is a resistor connected to pin7, check the voltage there instead of on the ic.
I suspect there is no vcc and the supply for the vcc comes from the standby circuit.
I am starting to think there is no power on signal from the main board. I suspect PC903 is the optocoupler that turns on the power supply
CN4 pin 2 standby should be the power supply on. With CN4 disconnected from the main board, connect pin 1 (3.3v) to pin 2 (standby) and see if you get your 12 volts.
Old 01-25-2022, 09:43 AM   #15
StromarMiki
ic601 pin7 no VCC
CN4 PIN5 no VCC 12V
Power in pin2 is 3V mainboard is work.
Old 01-25-2022, 10:53 AM   #16
R_J
City & State: ☻
My Country: Canada
ic601 pin7 no VCC
CN4 PIN5 no VCC 12V
Does ic601 pin 7 connect to J17 and then to J9?
How do you know the main board is working and sending the power ON signal?
Old 01-25-2022, 12:38 PM   #17
StromarMiki
when connect CN4 on main board in pin 2 have 3v vcc.
and dont have 12v. I thinks is problem in power board.
Old 01-25-2022, 01:03 PM   #18
R_J
City & State: ☻
My Country: Canada
Does the voltage on pin2 change when you press the power button?
CN4 pin 1 is the standby 3.3 volts that supplies the main board, CN4 pin 2 turns the power supply on and off.
Old 01-28-2022, 11:03 AM   #19
StromarMiki
When I connect the power cable to 220v only red led blinking.
The main board works but reports an error.
Voltage failure is possible.
Old 01-28-2022, 12:26 PM   #20
R_J
City & State: ☻
My Country: Canada
Here it is listed under layer 1
Badcaps.net Technical Forums © 2003 - 2022
