Ohms Law question - kind of ...
  • EasyGoing1
    Shock Therapist
    • Sep 2016
    • 977
    As most of you are well aware, the whole vaping thing has become fairly popular lately... I was having a discussion with someone in that realm who builds coils and the issue of current flowing through a coil came up and so I did a quick calc for the current going through a coil whose resistance is .15 ohms with an applied voltage of 8.4 volts, and I came up with 56 amps ... which is a hell of a lot of amps ... but doesn't seem inconsistent given the effects it has on the coils ...
    But then I started to think about it and realized that 18650 batteries are not capable of delivering 56 amps ... so naturally, something has to give in the equation and that something has to be voltage because the resistance is static...
    However, two fully charged 18650 batteries in series, will be 4.2 * 2 = 8.4 volts ... yet they aren't capable of delivering 56 amps to a .15 ohm load ...
    So ... how does THAT work? Does the voltage somehow drop when the batter is being taxed that heavily?
    sigpic
  • petehall347
    • Jan 2015
    • 4424
    • United Kingdom
    Re: Ohms Law question - kind of ...
    highest rating you can get is 3.6AH as far as i know .
      • Jul 2011
      • 6025
      Do you actually have one of those coils to do this measurement correctly I am just asking the question not wanting to counter dictating your results with ohms law math but actually testing the coil circuit working would be interesting to know what this circuit does and how it does it
      No I am not a nicotine user at all but have wondered how this technology actually works
        • Jul 2011
        • 6025
        If you short a 18650 monetary you can get upwards of 6 to 8 amps this however is not recommended to do and things can go horribly wrong quickly if done to long ( this depends on the series of battery that we are talking about because most of them are limited to 4 amp according to the data sheets )
        • petehall347
          • Jan 2015
          • 4424
          • United Kingdom
          if i calculated right about 50 amps for 5 minutes
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8678
            ohm's law doesn't work here only because the circuit isn't fully modeled.
            ESR is being improperly ignored.
            • PeteS in CA
              • Aug 2005
              • 3578
              • USA, Unsure of Planet
              IOW, the battery has an internal resistance which would drop some of the battery's voltage if connected to a .15 ohm load (ignoring the inductance and charge time of the inductance).
              PeteS in CA
              • EasyGoing1
                Shock Therapist
                • Sep 2016
                • 977
                I vape with a "controlled mod" - which is basically the circuit I described only it has a microcontroller and it varys the current through mosfets based on parameters you set.
                HOWEVER, I absolutely do have multiple 18650's - the high drain rated ones and I have a ton of raw coil material so this would not be a difficult experiment to set up at all.
                My only concern is that this new Fluke meter has fuses in it for the current settings ... my other Fluke does not ... but I'll be damned if I know where it is. But I think the Fluke is able to read up to 50 amps maybe?... I already blew a friggin $20 fuse but that was before I even realized it had fuses that you could blow ... which I think was on the microamp setting or something ... either way I fucked it up and had shell out $20 for a fuse and now I'm paranoid about it ... but I shouldn't be, I should just know its limits and make sure I don't exceed them ... lol
                sigpic
                • EasyGoing1
                  Shock Therapist
                  • Sep 2016
                  • 977
                  Esr is being improperly ignored.
                  esr?
                  And ohms law HAS to work here because ... being a LAW and all ... just need to figure out what I'm missing ... and Petes in CA mentioned internal resistance of the battery ... that might be something to consider as it would certainly have a real causal affect on the circuit...
                  sigpic
                    • Jul 2011
                    • 6025
                    You could use a meter that has a external shut something like 100 to 300 amp they are not very expensive I have bought couple of them and have used them in the past and seem to be fairly accurate
                    • EasyGoing1
                      Shock Therapist
                      • Sep 2016
                      • 977
                      Look at the amp rating of the batteries I use for my vape...
                      sigpic
                      • eccerr0r
                        Solder Sloth
                        • Nov 2012
                        • 8678
                        See you neglected that 0.16Ω printed right on the battery (which is the "ESR" or "internal resistance", and this value changes as the battery ages, per lot, state of charge, etc., etc.)! That's why Ohm's law is not working for you.
                        Actually looking at that again, probably need to rotate that battery some. 160mΩ seems very very high for a battery designed to pass 22A continuous. Should be much less than 160mΩ, probably on the order of 10 to 20 mΩ.
                        • redwire
                          • Dec 2010
                          • 3900
                          Life 4 battery datasheet. The "0.16Ω" spec is the 'ohm limitation' to achieve "non-stop CDR power". CDR is the continuous discharge-rate where the cell apparently does not overheat. You can draw more current- but the battery will quickly overheat. It naturally does make it's own heat due to the battery's internal resistance, ESR.
                          A way to look at is everything has resistance. The battery (internal resistance), the switch+wiring+battery holder contacts, the heater resistor.
                          So all of them will make heat, the question is who can't take it, what is their limit.
                          A 0.16Ω coil with 8.4V is 52.5A/441W which is not realistic. In real life the battery's voltage will sag under overload well below 8.4V, they can't put out more than 31.5A before blowing up anyway.
                          The heater coil will likely just blow up as they are maybe 80W at most for a few seconds. It will also overheat and melt the wire.
                          Do you see as you increase the power, the heating element runs hotter, the batteries run hotter, the switch/wiring run hotter - losses go up. Which is fine unless it's too much and the part roasts and burns up.
                          • eccerr0r
                            Solder Sloth
                            • Nov 2012
                            • 8678
                            Indeed 0.16Ω is declared to be the minimum resistance of the load for one cell that's printed but couldn't read because the label needs to be rotated a bit...
                            However if 2 cells are in series, then the minimum load resistance should be 0.32Ω. So either way yes the batteries are being abused. With the two batteries in series and a 0.16Ω load, assuming 0.02Ω ESR per cell, the cells would droop over a volt a piece, and burn 26 watts for each cell (though with the voltage droop, not really this much but still) ... quite hot! Not healthy at all and you wouldn't get anywhere near full power on the 0.16Ω load.
                            • AppleLover123
                              Asus Ux51vz no picture
                              by AppleLover123
                              Hey guys,
                              ive got a laptop here with a very strange fault.
                              As the title says the Laptop turns on Power Button lights up as well as the keyboard but no picture.
                              At first i thought it was a bios issue or a ram issue but the fans are not spinning either (or is this normal?).
                              I checked the board and found that vcore 1 from the CPU is good and the other vcore with the two coils has 0.6 ohms to gnd. I found that strange because if the vcore got shorted like from a mosfet it wont have a working Main Power rail.
                              Now the Question is: Is the 0.6 ohms normal?
                              03-12-2025, 02:17 PM
                            • narf
                              Epson EB-U42 projector / Caps with 0.7 ohms ?!
                              by narf
                              hi all,
                              first of all: i'm a (motivated) newbie, so please forgive me any stupid question i may or may not ask
                              i'm currently repairing a projector: Epson EB-U42 that doesn't start (no lights, nothing).
                              what i've found so far:
                              - the PSU does its job and supplies 12V to the mainboard via the connector.
                              - shortly thereafter, there is a mosfet (TS420-600B) where i can test 12V on the one side (in the data sheet this side is called Anode), Gate 0V, Kathode shorted to ground
                              - not far away, there's the first cap with a resistance of 0.7 ohms....
                              07-02-2024, 03:53 PM
                            • Sephir0th
                              DELL XPS 15 9560 - No VCore, Power Off after few seconds
                              by Sephir0th
                              Hello Community,
                              i'm troubleshooting this one since days and actually i'm really lost because i believe i'm Missing the required experience for an issue Like this...
                              It is a Dell XPS 15 9560, i7-7700HQ, GTX1050 Board Number LA-E331P Rev 1.0, Most similar to LA-C361P so i use this Schematics.
                              Issue: Starts and shuts Off after a few Seconds. Basic Troubleshooting (Adapter,RAM,BIOS/EC Flash from alisaler) of course already done, which didn't Changed anything.
                              I have another working Board with i5-7300HQ and GTX1050, with It's Help i can compare...
                              05-09-2021, 11:22 AM
                            • Nagyesz
                              Lenovo ideapad 330ICH - Dead, no volts on coils
                              by Nagyesz
                              Hi everyone, I replaced this motherboard because it was important to get it working, but it's been with me for a very long time. Now I finally have time to figure out what the problem is,
                              I've never encountered something like this before;
                              No charging light, full dead
                              Lenovo Ideapad 330-17ICH
                              • PL3102: 5 ohms
                              • PL3001: 3.2 ohms
                              • PL3101: 2 ohms
                              • PL5801: 3.5 ohms
                              • PL5501: 270 ohms
                              • PL701: 35 ohms
                              • PL501: 146 ohms
                              • PL503: 390 ohms
                              • PL402: OL (0.27V) +5VALW_P
                              • PL301: OL
                              • PL401: OL (0.03V) +3VALW_P
                              + Dc-in mosfet @PQ311 pin 5 20v, pin 1-4 0V , @PQ312 no volts...
                              10-11-2024, 10:12 AM
                            • reessi
                              Acer Alienware Nitro 5 (GH51G LA-L181P Rev: 1C) & Dell Alienware M15 (GDP50 LA-k452P Rev:1) - Both Shorted PCH (SRKMA)!
                              by reessi
                              Hello:
                              I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
                              I started on the ACER:
                              Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
                              All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
                              I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap...
                              10-29-2024, 11:31 AM
