Apple 85W MagSafe Power Adapter - blown - help with component identification
  • duwane
    • Mar 2022
    • 55
    • New Zealand
    Hi All.
    I have an Apple 85W MagSafe Power Adapter (Model No: A1343) that has a blown power MOSFET (Q050 - Infineon IPP60R299CP - - all 3 pins dead short). When the FET blew it took out an SMT resistor, as well as possibly vaporizing an entire capacitor and its pad (see attached photos). Hopefully that will be all that is blown, but until I can replace the FET and the other physically damaged components I can't tell.
    The burned resistor and cap in question are located underneath the large main cap (as seen in 2nd and 3rd images).
    Is anyone able to measure what the value of R051, and confirm if C052 is actually a NO STUFF? By the looks of the remaining pad for C052, it could very well be a NO STUFF as the solder looks undisturbed. Just weird that one pad would vaporize if there was no component there. I have cleaned off most of the carbon in there (there was a lot!) for the photos.
    Attached images to help identify and/or locate the components I am referring to. In the first image I am showing the board layout with the main cap in the top left. In the second image, I have bent the main cap upwards to see the other components underneath that are damaged/burnt. Third image is a closeup of the burned area and damaged components.
    I am hoping someone either has a schematic, or is able to identify the components, or if someone has a working adapter to see what the values are that would be greatly appreciated.
    Any and all help appreciated, and thanks in advance.
  • PeteS in CA
    • Aug 2005
    • 3578
    • USA, Unsure of Planet
    Re: Apple 85W MagSafe Power Adapter - blown - help with component identification
    My compliments for the clear pictures.
    The first two characters on the fried resistor appear to be "R" and "1". The third character could be "0", "8", or "9". I'm guessing this resistor is in the Source circuit of the switch MOSFET, a current sense resistor. .10 or .18 ohms seem the most likely possible values.
    I think that capacitor location was unpopulated, for the reason you mentioned. On the other hand, it looks like the trace near the "C" of the reference designator started to fuse. At the least, it will have to be reinforced. That partial fusing means that the trace was carrying significant current until something else opened up first. The cause of the MOSFET shorting may yet be in the adapter. Lite On is a good power supply company.
    PeteS in CA
    • R_J
      • Jun 2012
      • 9535
      Usually when a mosfet source resistor is open, the drive/controller ic is also damaged because the ic's CS pin can see very high voltage as the resistor goes open. There is likely a small resistor between the mosfet source and the controller CS pin
      • duwane
        • Mar 2022
        • 55
        • New Zealand
        You are most welcome. Thank you for trying to help out. It makes sense to post clear pictures so that people can actually help. No point posting potato cam pics, and expecting much assistance
        Yeah I thought a low value too, but it still gives a reading of 19.6k ohm on the multimeter, so threw that thought into doubt. Also with the amount of heat it appreas to have taken, I don't trust its current reading.
        Could just have fused due to heat from the resistor maybe? Just hard to beleive that even the pin end of the capacitor would dissapear entirely, so at this stage the only logical explanation is that there was never any capacitor there.
        Pretty common for power FET's to die based on my experience. Can be caused by voltage spikes, weakness in the junctions inside the chip itself, etc., but yeah hoping its nothing more than just the FET and resistor lol
        • duwane
          • Mar 2022
          • 55
          • New Zealand
          Thanks for helping out.
          The reistor still reads 19.6k ohm on the multimeter, so luckily didn't die OL, so I am hoping that the drive chip didn't get hit too hard. I don't trust this reding though, as the resistor must have gotten really hot to burn the paint off and melt the track pad and solder next to it.
          • R_J
            • Jun 2012
            • 9535
            That source resistor is OPEN, it should read LESS than 1Ω, not 19k! The Source resistor connects the mosfet source lead to ground. Now as far as the circuit operation, the resistor I was referring to is a different one. And I will bet money that the ic is blown.
            Here is a simple smps, Rcs is your burnt resistor, Rcsf is the one I am referring to.
            The drain of the mosfet has a min 160vdc, when the mosfet shorts D~S and the source resistor goes OPEN, approx. 160vdc is applid to CS (most ic's can handle about 5v on this pin)
            Another path to ic destruction is a short D~Gate, then 160v is applied to the OUT of the ic, it can't handle this.
            This is just a sample circuit, your ic etc. will be different but similar in operation.
            • duwane
              • Mar 2022
              • 55
              • New Zealand
              Roger that, thanks, and thanks for the explanation. I will pick up some controller chips as well just in case. They seem to be relatively cheap on AliExpress, so will replace this as a precaution as well.
              When I measure the uquivalents of RBleeder, and RG on your example curcuit, they both read as OL but show no signs of heat damage (they are on the underside of the board), so may end up having to replace them as well.
              • R_J
                • Jun 2012
                • 9535
                What is the controller number in your power supply?
                • duwane
                  • Mar 2022
                  • 55
                  • New Zealand
                  Originally posted by r_j
                  what is the controller number in your power supply?
                  lta910n
                  • duwane
                    • Mar 2022
                    • 55
                    • New Zealand
                    I can't find a specific datasheet for the LTA910N chip, but I did find this PDF on the manufacturers website when I search for LTA910N:
                    https://cdn.badcaps-static.com/pdfs/...f7f355710b.pdf
                    It seems that the LTA910N chip interacts with the other chip on the board (TEA1762)
                    • duwane
                      • Mar 2022
                      • 55
                      • New Zealand
                      Found the datasheet for the other chip on the board:
                      https://cdn.badcaps-static.com/pdfs/...64b3703f8a.pdf
                      • duwane
                        • Mar 2022
                        • 55
                        • New Zealand
                        Took a photo of the underside to show what I am talking about.
                        Circled in red is the LTA910N, and TEA1762.
                        Circled in green is where I have now removed the FET from.
                        Circled in yellow are the 2 resistors (RBleeder, RG) that also seem to measure as OL, so assuming they are also damaged.
                        • R_J
                          • Jun 2012
                          • 9535
                          One is a 4R7 (4.7Ω) and one is 101, (100Ω) also the diode T4 (1N4148) may be damaged, These are in the gate circuit.
                          The 4.7Ω and the diode are across the 100Ω, these components are between the mosfet gate and one of the ic pins, Can you see which pin it connects to? likely either pin 10 or 12
                          • duwane
                            • Mar 2022
                            • 55
                            • New Zealand
                            One is a 4R7 (4.7Ω) and one is 101, (100Ω) also the diode T4 may be damaged, These are in the gate circuit.
                            T4 diode seems to be fine, It measures 0.565v drop in one direction on diode tester, and OL in the other direction
                            • duwane
                              • Mar 2022
                              • 55
                              • New Zealand
                              What wattage would you say those 2 resistors are? Also trying to decide what wattage the unknown resistor might be as well.
                              • R_J
                                • Jun 2012
                                • 9535
                                The two gate resistors are low wattage (1/8w?) the other one might be around 1~2 watts? being very low resistance the wattage won't be to high. measure it's physical metric size. You will need to know the resistance as it is important to the operation as the current through this resistor controls how the circuit operates
                                • duwane
                                  • Mar 2022
                                  • 55
                                  • New Zealand
                                  Yeah thanks. Hoping to find that value. After looking at the numbers on the unknown resistor again, my guess is it says "R170" which would be 0.17ohms. Still hoping that someone can confirm if they have one of these sitting around somewshere.
                                  I am working through using the measurements of each one to get package number. I guess I could just buy the highest available wattage with the same package number.
                                  • R_J
                                    • Jun 2012
                                    • 9535
                                    Try cleaning that burnt crust to see if the other numbers are reviled
                                    • duwane
                                      • Mar 2022
                                      • 55
                                      • New Zealand
                                      I tried, but the parts that are not visible are actually missing/burned paint. I just removed that resistor, and it has a crack right through it (it fell into 2 pieces when I desoldered.
                                      • duwane
                                        • Mar 2022
                                        • 55
                                        • New Zealand
                                        Sorry, only just saw this. It connects to pin 13. I have taken another photo now that I have removed the 2 resistors, the FET, and the IC.
                                        There was some sort of hard underfill in a circular blobs under the chip which I can't remove, so its not so clear or easy to see. Sorry. The exposed tracks were underneath the fill.
                                        • x_orange90_x
                                          Sony Bravia KD-50X690E blown resistor
                                          by x_orange90_x
                                          I just picked up this tv yesterday and the previous owner said while watching tv he heard a loud a pop and then the screen went dark. I removed the back cover and found the source rather quickly; resistor R8601. A chunk of the ceramic had blown off exposing the inner wire. Due to the damage I cannot make out the colors of a couple bands. I likewise cannot find a datasheet for the power supply. I tried pulling up pictures of the same board online but the resistors have different colored bands which I half expected as I've had this happen before.
                                          The power supply is 715G8413-P01-001-0H2S...
                                          07-16-2024, 06:53 AM
                                        • bastyani
                                          Apple 85W MagSafe Power Adapter - blown - help with components
                                          by bastyani
                                          Hi, I have an 85W MagSafe Power Adapter, Model No: A1343, worked ok,
                                          then suddenly dead. Opened it up and there are a few components blown.
                                          Two resistors and a chip.
                                          You can see more on the attached pictures.
                                          Unfortunately I can only read the few last characters on the chip - an N on the top and 3261 or 5261 on the bottom (can't rally tell, the character is halfway visible but most probably is a 5261). The chip is blown right on the position where the model/type is printed. The resistors are also hard to tell.
                                          Can anyone of you experts...
                                          04-09-2021, 03:30 AM
                                        • redbaron1007
                                          Arcade PSU blown resistor ID
                                          by redbaron1007
                                          I'm working on one of the PSU's in my backlog today that came out of an NBA Jam arcade machine a year or so ago. The PSU is a Pan Yes brand with a model number PY-TV-C. From what I remember the 12v rail wasn't outputting anything. I opened it up and was reminded that the resistor at R28 had blown it's shell off and I have no idea how to ID a replacement for it. (see pictures) The color bands that are still intact a little are brown, black, missing band/bands, and what I'm assuming is silver. When I check it with my DMM it's reading 100ohms exactly but I don't know if that's what it's supposed...
                                          01-06-2023, 04:13 PM
                                        • bumper1
                                          Razer Blade 15 RZ09-0328 DA550-MB - resistor identification
                                          by bumper1
                                          I have Razer Blade 15 RZ09-0328 MOBO: DA550-MB MP V4.0 20200227 with liquid damage.
                                          I need to know value of resistor on photo. Thanks for help. ...
                                          07-10-2025, 03:34 AM
                                        • GottaBeGrim
                                          PNY RTX 3060 12GB single fan resistor identification
                                          by GottaBeGrim
                                          hello, i have the gpu in the title and a resistor fell off that i need help finding the resistance of. does anyone have the schematic or the resistance value? see images below for the one missing....
                                          01-02-2025, 08:11 PM
