Dell Latitude BIOS Read Issue - XMC25RH256CXIQ
  • CapThatBrass
    • Oct 2021
    • 46
    I'm looking to read the BIOS/image contents of an XMC 25RH256CXIQ chip but I can't find any programmes that are compatible with it (in combination with my CH341A programmer). AsProgrammer 2.1.0.13, NeoProgrammer 2.2.0.10 and Colibri all show no matches for the chip, although they do detect a chip being present.
    Any help would be great.
    Cheers
  • anhbanxoi
    • Sep 2021
    • 170
    • VN
    Re: Dell Latitude BIOS Read Issue - XMC25RH256CXIQ
    https://www.badcaps.net/forum/showth...=100654&page=4
    Take a look at post #80
    • CapThatBrass
      • Oct 2021
      • 46
      Thanks Anhbanxio.
      So from what I've read on post #80, the XMC25RH256CXIQ shares the same properties (with programming interfaces/applications) as the MX25L25635E, XM25QW256C and W25Q256BV chips? So selecting the chip profile for one of these models should provide the correct output?
      • JAFATAGNA
        • Apr 2016
        • 58
        • MARRAKECH
        hi i have RT809F with last update 20221212 i cant read XMC25RH256CXIQ not in list i use MX25L25635E but dump is not working can you help mais plz
        • flores
          • Nov 2023
          • 26
          • romania
          Hello. How can read xmc 25rh256cxiq ?
          • gizaha
            Dell Latitude 5580 possible bios corruption
            by gizaha
            Dell latitude 5580, motherboard cdp 80 la-e151p
            3 amber 3 white blinks. Dell website sais it's problem "bios recovery" and suggested solution "recovery image not found"
            (from here https://www.dell.com/support/manuals...e7a&lang=en-us)
            I try plugging charger while pressing ctrl+esc, machine turns on, nothing and after 20 seconds it gives 3 amber 3 white blinks again.
            Since ssd is replaced and had clean install windows, i've...
            02-13-2024, 07:18 AM
          • TripTop
            Dell Latitude E7270 - Requesting BIOS clean/corrupt? service tag CB00KC2
            by TripTop
            Hi
            i have dell latitude E7270 with following symptoms:
            - takes long time to restart.
            - sometimes powers on and then off
            - sometimes while working it just dies,
            From googling online bios clean could possible resolve this?
            i was able to save bios and was going to try bios clean myself but get an below error when i drop it in ME analyzer.(unsure whether this sometimes occurs or could be due to bad/corrupt bios)
            As ME analyzer gave me an error i just decided to write bios with a cleaned bios from E7270 bios post.
            I reinstall...
            09-09-2024, 02:05 PM
          • Eradicatus
            Dell Latitude E5550 - Strange Internal LCD (BIOS?) Issue
            by Eradicatus
            I have a problem with my Dell Latitude E5550 laptop, in particular with its display.
            This laptop has been sat under my desk (unused) for quite a while and I wanted to reinstall Windows and use it for some ad-hoc testing.
            However, I am struggling with the display, which is playing up.
            1) When the laptop is left switched off, after switching it back on the internal LCD does not work. No images are displayed at all - no DELL logo on POST, no messages, no Windows desktop. But I can hear that Windows starts up correctly, so no issues with the rest of the system - must be...
            04-20-2022, 02:40 AM
          • NotEnough
            Dell G15 5515 RGB Keyboard Not Detected (Compatible Keyboard, Possible BIOS/EC Issue?)
            by NotEnough
            Hi everyone,
            I'm working on a Dell G15 5515 (Ryzen 7 5800H, RTX 3050 Ti) and recently installed a compatible 4-zone RGB keyboard and controller (for Dell G15 5510/5511/5515 models). While the keyboard functions for typing, the RGB lighting is not detected by Alienware Command Center (AWCC), which displays “No AlienFX devices found.”
            What I've Tried So Far:
            • Reseated the cables.
            • Reinstalled AWCC and AlienFX services.
            • Attempted BIOS downgrade but no improvement.
            • Inspected ribbon cables for damage.
            • Explored the possibility of BIOS or
            10-19-2024, 01:34 AM
          • Loli Popu
            DELL LATITUDE 5590 BIOS CORRUPTED BY CH341
            by Loli Popu
            Hello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
            12-13-2024, 08:29 AM
