Esprimo Q9000 CMOS battery discharges constantly and extremely quickly
    at the Fujitsu Esprimo Q9000 Mini PC the cmos battery discharges in a very short time (a few hours) does anyone have an idea what the reason is
    sorry for my bad English
    Re: CMOS battery discharges constantly and extremely quickly
    You need to check the resistance on the + pole of the battery connector, should be in Mohms range, if you have it lower, then somethings draws too much power, most probably the chipset (where the cmos memory is located), as if i'm right there is not a lot other things connected to the CMOS battery, potentially also the Super I/O chip as it usually monitors the battery voltage and is connected almost directly to the battery. Often there are also a few passive/active compontents connected to the + pole of the battery (usually near the battery), a RC nerwork, or a key mosfet, cap (mlcc) or mosfet (eg. 7002) might have a short. Try to find a boardview or schematics.
