HELP !!! Gigabyte Auros X470 Gaming Wifi 7 - Identifying IC
    Hi guys,
    I've got hold of a mangled board mentioned in the title. Board work OK but had missing Audio and DAC IC's, which I've ordered from AliExpress.
    BUT, on the underside of the board (under the DAC chip), there should be an IC, im guessing a BIOS.
    Can someone help me identifying this IC ? If it a BIOS for DAC, can someone provide me with the .BIN file for it as well ?
    Thanks in advance.
    Re: HELP !!! Gigabyte Auros X470 Gaming Wifi 7 - Identifying IC
    Typo - Aorus
      Anyone help please ?
        Post a picture of the area where the missing IC is
          You can get the bios from the support wesite,there are 2 different revisions,at the top left is the revision number you can select
          https://www.gigabyte.com/Motherboard...WIFI-rev-11#kf
            Hi, you've misread the BIOS part. I'm not sure if the missing IC is a BIOS or something else. The IC is on the other side of the board, directly under the DAC IC.
              Right,i`m with you now .Post pictures.I can`t find a schematic or boardview for the board,but there are some others available that might have the same IC layout
                Thanks. Not sure if the X570 version has the same DAC.
