GTX 690 not recognized after overheating
  • kkarsaj
    • Jun 2022
    • 4
    • Ireland
    Short and simple - today I was idiot (more than usual).
    Subject: Dell/nVidia 690 GTX
    Story - got this beautiful piece of engineering for low price in great condition and got distracted during cleaning & changing paste ending up with overheating after 3-4 min of testing and ... it's dead Jim. Beeeeeep bip bip bip bip.
    Tried to troubleshoot it (stopped at shorts testing, couldnt bare the sadness and anger), but I decided to seek for some wisdom here.
    I've marked mosfets and "pex8747 ba80gbc" SLI thingy on the attached photo where I forgot to put thermal pads. I would really appreciate if someone drop advice or two on what to test; if not, lets this be testament of "multitasking, what could possibly go wrong".
  • cyberwillis
    • Jan 2022
    • 5
    • Brazil
    Re: GTX 690 not recognized after overheating
    Hello...
    What exactly you did by distraction ? Just forgot to put pads ?
    Have you tried to check the Fuses ?
    • cyberwillis
      • Jan 2022
      • 5
      • Brazil
      I don't think for 3 - 4 min it would cause your board just die because you forgot the thermal pads.
      To me appear that the PCIEx have bad contact or the Fuse get blown.
      Why I am asking you take a look on the Fuse F1 (close to the M3 memory)? I was used to deal with boards without turning off the power supply cable I was just taking off boards and putting again carelessly until last year I get a HBA board to deal with, and damn they are SO SENSITIVE. If you have a HBA board and your machine is with your power supply cable attached, 99% sure the two fuses will blown and you will not notice that and your HBA board will not even turn on. So even if you had stressed your GPU board and believing it was fine why a overheating of 4 min would make your GPU die ? Don't make sense. There is other part of story you not telling ? Like forgot to turn on the Fan or something else ?
      • cyberwillis
        • Jan 2022
        • 5
        • Brazil
        Also, I started to notice in your picture there is too much flux around the PLX chip (PEX8747), somebody tried to reball it? May be if that was the case, and the ball used was poor quality may be because overheating the process was undone. Because that area should be clean from flux.
        • kkarsaj
          • Jun 2022
          • 4
          • Ireland
          Hi
          tnx for reply. I did check F1 and it's OK and the flux, that was me as well (just a quick heat up, not reflowing or reballing).
          It happened just as I described - i forgot to put pads on mosfets and PLX, everything else was OK. Card worked for - how much time is needed to boot up and finish 50% of 3DMark Vantage (less than 5min) - then died (screen went black and after restart - beep bep bep bep). Tried on few different MBOs, same thing and GTX 580 works fine in that system where this one died.
          Now im waiting for new PSU (other one with 2x8pin cables is in my sons computer) to continue...
          One more thing - now, when powered on, even without fan and metal parts, its completely cold as much as i can feel (don't have thermal cam). Also, fan is spinning when connected and the logo LED has power
          • cyberwillis
            • Jan 2022
            • 5
            • Brazil
            Yeah if another GPU works fine in that system is not related to the MOBO itself nor the PCIex.
            The power supply failure is possible, just a note this GPU needs 300W for it alone so preferable use a PSU that has 450W to Up. At this point is hard to tell if is something got damaged on the power connector or not. Can you verify if there is shortcircuit in line 12V?
            • kkarsaj
              • Jun 2022
              • 4
              • Ireland
              Yeah, no shorts found. I used Antec 750W when this thing died (same PSU is running happily with AMD FX8150 & GTX 580 now).
              tnx for now, i have to wait for PSU before i continue with troubleshooting.
              • Ven
                Dell Latitude 3510 Overheating & Fan Control Issue – Need Help
                by Ven
                Dell Latitude 3510 (Intel Core i7-10510U) CPU Overheating
                Issue Description:
                1. CPU Overheating to 100°C
                  • When I start the laptop from a cold state, it takes about a minute to reach temps around 80-90-100°C, and CPU thermal throttling triggers.​
                  • When the CPU fan is running at full speed (by disconnecting PWM and TACH cables), CPU temperature stays around 50-60°C.
                  • However, when the fan is connected normally to the motherboard, it does not kick in at high temperatures.
                  • I also noticed a few times that the fan kicked in for a very short time, but it does not stay on consistently.
                  • Thermal
                02-12-2025, 03:57 PM
              • Zilicon
                Elitebook 840 G1 HDD not recognized, Please help
                by Zilicon
                Greetings everyone.
                please, help assist me with the above PC problem.
                The boars number is 6050A2559101-MB-A03. The PC does not recognized HDD, neither does it recognized NGFF SSD.
                i discovered that the HDD does not spin.
                there were activities at the SATA connection.
                Pin 2,3,5,6 rises to 400mv then jump to about 4v, again to mv. It continues in loop that way. Same behaviour at pin 20,21,22.
                5v is present at 14,15,16.
                Pin 18 which is reserved has about 1.8v, sometimes it increases to 2v+.
                Pin 8,9,10 is...
                06-16-2025, 12:11 PM
              • sancho76
                thickness of thermal pads for Alienware M15 R1
                by sancho76
                Hi, somebody knows the thickness of thermal pads for M15 R1? Or if someone have this Alienware model, can take measure for original thermal pads.
                02-01-2025, 03:19 AM
              • dbuergi
                Restore solder pads for SMC on MacBook A1466
                by dbuergi
                i got a A1466 logic board for spare parts but it looks like the SMC ist bad. I got several spares but somehow i was too fast while removing it and ripped some pads off. You can see the damage attached.
                Just for experience i would like to restore the lost pads but before i start (haven't done this before) do you have some hints or tutorials how to do it?
                As written i want to improve skills so it doesnt matter if it takes longer.
                12-29-2024, 10:24 AM
              • supravit2000
                Sony PS4 ADP400DR - help needed figuring out shorted pads under capacitor C 31
                by supravit2000
                Hi!
                A friend of mine gave me a dead PS5 to look at. I am totally inexperienced, but when a damage is simple (i.e. failed DAP41 on PS4s, etc.), when replacing just the IC and the other very common failing parts of these consoles, problem is fixed. So I checked the voltage of the PSU - none was present. Model is ADP 400DR. I have a bunch of spare parts around, so first thing I did was to replace the IC DAP 053 (they seem quite expensive, so I put a replacement unit - TEA2016AAT. When plugged to the power outlet, 12V did come present.
                So I reassembled the PS5 and pressed the power...
                07-20-2024, 07:26 AM
