#1 |
Sure Not
City & State: CapCity
My Country: Resistron
![]() It has 5V, 3.3V. No shorts on coils. Power button works correctly, when pressed voltage drops.
One time turned on. Not sure how. |
#2 |
City & State: Windsor, Ontario
My Country: Canada
Line Voltage: 110VAC
![]() Which board is yours ?
#3 | |
City & State: York
My Country: UK
![]() https://www.badcaps.net/forum/showthread.php?t=88758
#4 | |
My Country: Canada
![]() Quote:
#5 |
Sure Not
![]() fixed by removing cmos battery and waited for some time, after few tries it worked. BIOS went mad i guess.
Other problem. trackpad doesnt work. I have second trackpad, and it doesn't work too. Under windows 10, device manager is not detecting any trackpad. Doesnt work on latest ubuntu and windows 7 install setup. Asus smart gesture driver is installed (W10). x550ld rev. 2.0 Last edited by mosfetratus; 07-07-2022 at 08:46 AM.. |
#6 |
My Country: Canada
![]() Review the voltages on the J3102 connector.
Most interested in the voltage readings of pins 3 & 4 which are the TP I2C interface pins (SDA & SCL). Meter in DC volts scale (5 volts or higher is ok). Red meter probe on pin # 3 of the connector; Black meter probe to ground. |
#7 | |
Sure Not
![]() Quote:
2. - 3.34v 3. - 3.34v 4. - 0.00v 5. - 3.34v 6. - 0.00v (2.80V when linux is booted). 7. - 0.00v 8. - 3.34v Last edited by mosfetratus; 07-07-2022 at 10:21 AM.. |
#8 | |
My Country: Canada
![]() Quote:
Pin 4 : something is wrong here. This should also be ~3v3. Remove all power -> check your cabling. Remove the cable for now. Power up and check the voltage on pin # 4 again. Still 0v ? If yes, power down again -> meter in resistance mode (lowest scale is ok). Check the resistance to ground of pin # 4 of this TP connector J3102. Post the measurements. |
#9 | |
Sure Not
![]() Quote:
Resistance of pin 4. is 0.1ohm - shorted. |
#10 |
My Country: Canada
![]() Resistance of pin # 4 = ~0 ohms to GROUND ?? (no power when testing resistance)
#11 |
Sure Not
#12 |
My Country: Canada
![]() Ouch! Review if you have a visible short on this line. According to the boardview diagram, this is a signal line and should be ~3v3 with no activity. This is common to I2C bus interfaces - the local pull-up performs this task.
The resistance is very low so suspecting that there is a solder short or a bad cap. Hunt the area for clues. Possible short could be to pin # 5 = GROUND on the same connector. |
#13 | |
Sure Not
![]() Quote:
your boardview file is wrong. pin 4 is ground. Which is correct. No problem with pin 4. pin 5 is TP_DAT pin 6 is TP_CLK Last edited by mosfetratus; 07-07-2022 at 12:17 PM.. |
#14 |
My Country: Canada
![]() Ok. So the TP connector = J3101.
What are the resistance readings for pin # 5 and # 6 to ground ? Also measure the voltage on each pin. |
#15 | |
Sure Not
![]() Quote:
pin 5 is always 3.34V pin 6 is 0V when bios, windows 7 setup. And 2.8V when in linux. C3004 is OK RN3034 is OK only suspect is U3001 Last edited by mosfetratus; 07-08-2022 at 01:30 AM.. |
#16 |
Sure Not
![]() FIXED
Was bad trackpad + bad cable. Working trackpad had broken cable [From the laptop with BIOS problems]. Not working trackpad had good cable [From the laptop with trackpad "problem"]. |
Thread Tools | |
Display Modes | |
