Repairs Acer Aspire 5740_5340 MS2286
    Hello!
    Please, help me!
    Notebook
    Model: Acer Aspire 5740_5340 MS2286
    All voltage is normal. They react to the power button. The fan spins and stops. There are no short circuits. BIOS flashed. EC flash did not reflash. Connected an external monitor. There is a scheme. Black screen. No picture. The laptop does not start.
    What to check?
    Thanks all!
    Re: Repairs Acer Aspire 5740_5340 MS2286
    Need to replace the BGA Radeon HD5470 graphics chip. These systems do not respond to diagnostic heat up.
      Hi ,
      First->reload Bios by removing CMOS cell and try to start and check at external monitor
      Second->Check voltages on RAM Coil and try replacing RAM or use in other slot
      Third-> Without power check impedance of each Coil (Big coils) for RAM and GPU
      For reference below is the help
      For Generations 1st, 2nd , 3rd,4th (Socket Processors)
      Impedance Measured should be above 300 ohm for below coils
      For (a) charging coils (b) +3V (c) +5V ( d) +1.8V (e) CPU core (f) CPU GFX (g) RAM coil
      Impedance Measured should be above 12 ohm for below coils
      For (a) 1.05V (b) +GPU core (c) +VCCSA
        I agree.
          check RAM section or first try replacing RAMs or check System power up with removing one stick at a time.
