Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Laptops, Tablets, and Mobile Devices > BIOS Requests ONLY!
Old 09-06-2021, 02:26 PM   #21
maxitaxi
City & State: gld
My Country: nedtherlands
Line Voltage: [email protected]
Default Re: RCUnlocker
ok, can test it on thursday. 2 days off :-)
maxitaxi is offline   Reply With Quote
Old 09-07-2021, 05:58 AM   #22
smiley60
City & State: Sharjah
My Country: UAE
Originally Posted by RethoricalCheese View Post
User error. Follow the instructions. You need 16MB chip modified, not 32MB.
you mean patching the ec 16mb bios is enough for removing the password
smiley60 is offline   Reply With Quote
Old 09-07-2021, 06:26 AM   #23
RethoricalCheese
City & State: Tartu
My Country: Estonia
Yes.
RethoricalCheese is offline   Reply With Quote
Old 09-07-2021, 07:09 AM   #24
smiley60
My Country: UAE
Yes.
I m living at the world of locked bios laptops
and want to check 9470m for now
Old 09-07-2021, 10:13 PM   #25
Seattle2021
City & State: Seattle
My Country: United States
Hi RethoricalCheese,
Per your request, I am again attaching the BIOS for the 1040 G1 after multiple unsuccessful unsoldering and reprogramming using the HP Unlocker and RCUnlocker, as well using a BIOS downloaded from HP and modified lower portion of the bin file. Please let me know if you need additional information. Really appreciated for your help
Seattle2021 is offline   Reply With Quote
Old 09-07-2021, 10:57 PM   #26
RethoricalCheese
City & State: Tartu
My Country: Estonia
Well, looks like programming issue. When you write, does verify pass aswell?
Old 09-08-2021, 09:46 AM   #27
Seattle2021
RhetoricalCheese,
Thatís interesting and theres a possibility I have a faulty programmer. The post write verify always passed without any issues, Iíve even done a read after write, and the comparison were identical as well. I will continue to seek for a solution and may need a new software program. Thank you again for all your help.
Old 09-09-2021, 02:57 AM   #28
maxitaxi
City & State: gld
Yes, my bad. Used the wrong version of my tool
This is the one I meant to give you.
Hi , i tried the TEST_2 file but result is the same. I can press F10 and get message 'entering setup menu'. After 10 minutes i press F1 and i get 'enterin system information' so laptops seems alive but stays in the last-message-screen.
Old 09-09-2021, 12:47 PM   #29
ibo
City & State: ankara
My Country: turkey
Wow very good tool thank you for this.
So this will also unlock HP G6 and G7 models?
and for this models i need to read the EC chip?
ibo is offline   Reply With Quote
Old 09-10-2021, 04:37 AM   #30
Haker5
City & State: Glasgow
My Country: Wielka Brytania
yes i sorted yesterday g6 all is working
Haker5 is offline   Reply With Quote
Old 09-10-2021, 08:32 AM   #31
maxitaxi
City & State: gld
i could send the laptop to you by DHL if that would help research ??
Old 09-11-2021, 10:20 AM   #32
LatinMcG
City & State: Tampa, FL
My Country: USA/Puerto Rico
Line Voltage: Tickles the tongue
i have Patch 840 g6 32Mb patch file no need to patch 16Mb.
also Locked
both 32MB included to compare.
EDIT!!
Nevermind i was given bad INFO due to language
next post is working patch
LatinMcG is offline   Reply With Quote
Old 09-11-2021, 11:05 AM   #33
LatinMcG
here is a better example 830 G6.. seems its just changing the 3F to 3C on some areas to make it invalid.
then flash original back after the 16mb is forced to unlock without desoldering.
https://www.mediafire.com/file/jiitk...Patch.zip/file
Old 09-11-2021, 12:06 PM   #34
LatinMcG
ok so this does work for 840 G6 32MB only... if you CleanME !
flash this then flash original after bios defaults and Security reset.
but 1 strange thing. notice $FPT goes was south to address 675000 strange..
so patch seems to be insert in the ME and descriptor is changed.
https://www.mediafire.com/file/4t3uh...Patch.zip/file
Old 09-11-2021, 12:53 PM   #35
RethoricalCheese
City & State: Tartu
My Country: Estonia
It has been known for a while but I did not go for this path because it requires 2 soldering and 2 turning on.
Only advantage is that it's not needed to remove motherboard.
Old 09-11-2021, 01:34 PM   #36
przemek_79
City & State: Łůdz
My Country: Poland
Great job thank you so much
przemek_79 is offline   Reply With Quote
Old 09-11-2021, 02:24 PM   #37
LatinMcG
Thumbs up Re: RCUnlocker
yes it does save time for clip users w good read write capability..
one thing it cold use is cleanME first then drop on patcher to make it universal.
maybe you could add a filename switch for hp like xxxx-HP32MB.bin ?
would save some people time for multiple systems at same time
Old 09-11-2021, 02:48 PM   #38
RethoricalCheese
City & State: Tartu
My Country: Estonia
I'm going to enable 32MB in the future anyway. Might aswell try that. But not a priority for now.
What clip do you use for wson chips anyway?
Old 09-11-2021, 03:19 PM   #39
LatinMcG
wson chips . .add solder on sides of pad w wire.
friend uses silicon that came w SVOD3
i desolder w metal shield and low temp
Old 09-12-2021, 07:08 AM   #40
LenBios
City & State: Hon
My Country: Ker
Hi RethoricalCheese;
hp 840 G5 need only 32MB chip modified, or 16MB?
Thank you
LenBios is offline   Reply With Quote
Badcaps.net Technical Forums © 2003 - 2022
