Acer Emachine La-4854P dead
    I'm not getting any voltage on PIN 5-8 of PQ11. If i jumper from PIN1 to PIN5 of pq11-system boots fine. So rest things are ok.
    So B+ is shorted somewhere but i was unable to find what is wrong.
    PR57/62/65 is ok. MOsfet at PQ10/11 and 12 is ok. I have replaced BQ24751a and checked all resistance near Charging ic.
    Any ideas friends??
    Re: Acer Emachine La-4854P dead
    Voltage on pin 2, 3, 4, 5, 7, 8, 10, 13, 21, 28 of PU5 (BQ24751A) when adapter is connected?
    Resistance to ground of B+ line?
    Resistance across PR57?
      My suggestion is check PQ10 carefully may be something leakage Drain with Gate...or try to replace this P channel mosfet.
        pin2-0.5v
        pin3-0.5v
        pin4-19.0v
        pin5-2.61v
        pin7-0.67v
        pin8-2.56v
        pin10-3.96v
        pin13-0.65v
        pin21-0.5v
        pin28-19.0v
        pr57-46.5ohms
        resistance to b+ line-infinity in diode mode.
          Replaced pq10/11/12-still no voltage in pin5-8 of pq11.
            measurements of bq24751a is only with ac adapter connected.
              Originally posted by mcplslg123 View Post
              pin2-0.5v
              pin3-0.5v
              pin4-19.0v
              pin5-2.61v
              pin7-0.67v
              pin8-2.56v
              pin10-3.96v
              pin13-0.65v
              pin21-0.5v
              pin28-19.0v
              pr57-46.5ohms
              According your measurement pin#4 voltage must low ACDRV not working..check pc 45 leakage or shortage.
                Yeh pin 4 voltage is wrong ,should be around 12v instead of 19v but I've already checked PC45 and its ok.
                Any further ideads?? This mb is driving me nuts......
                  Check again your fets.
                    checked again-not faulty. Still changed them-no result.
                      pin2-0.5v
                      pin3-0.5v
                      pin4-19.0v
                      pin5-2.61v
                      pin7-0.67v
                      pin8-2.56v
                      pin10-3.96v
                      pin13-0.65v
                      pin21-0.5v
                      pin28-19.0v
                      pr57-46.5ohms
                      Resistance across PR57 should be 0.015 ohm, check again. If it's way higher than that it may be bad. Don't forget to take into account the resistance of your multimeter leads and the accuracy of the measurement, the reading may be off by a small amount for such a low resistance.
                      Voltage on pin 10 should be around 3.3V, if it's not you may have a defective charger IC.
                        Any ideas friends??
                        let`s keep things simple,first in diode mode measure pq10 , pq11 ,pq12 and reverse black and red probe,
                        should find something like 490V and OL other side.p channel 4407 is easy to find on scratch boards.and let me know.
                          Those are very basic things. I have already checked those things before posting for help. Anyway, thanks for your ideas Bachir sir
                            I have replaced charger ic twice-the last one from a workig board just to be sure. So charging ic is not bad-100% sure. It should be 3.3v on pin10 but i'm getting a bit higher 3.9v.
                            PR57 is ok-i have measured by taking resistance out of the circuit and even replaced it. No result yet.
                            I have removed lan/cardreader/sound ic.
                              Check the function of PU1( LM358 )
                                I have checked LM393 as well as LM358A-no problem found, even replaced them. No luck yet.
                                Client has agreed to take back laptop without charging enabled as his battery is almost dead and he dont wants to buy a new one. So I'm about to deliver it to the client today.
                                Would have been happier if could have solved the case as its always a learning lesson.
                                Still thanks for all your time.
                                  hello
                                  did you get the solution
                                    No , I delivered it to customer with charging disabled as customer agreed as mentioned in post#16
