Bush LED4012FHDCNTD Backlights
    Hi all, I have a Bush LED4012FHDCNTD with a backlight fault.
    TV comes on as normal, backlights go out after a few mins, volume still present etc.
    Stripped it down and tested strips and all LEDs illuminate, have illuminated strips individually for half hour and non go off.
    Just wondering how I would connect tester to the plug to light the whole array? As there are 3 wires (pic attached)
    Re: Bush LED4012FHDCNTD Backlights
    All sorted now
      So what was the root cause of the issue then?
      Related to this thread? https://www.badcaps.net/forum/showth...216#post940216
        1 faulty LED, it went out eventually.
        Have replaced it and so far the TV has been running fine, been on a few hours now
        No not related to that one, suprisingly, they have the same model numbers, but are 2 completely different sets in every way
          I actually got this one, thinking they would be the same, and I could swap out the boards to diagnose the other one, but the model number is the only similarity
