MacBook Air 820-00165-A PPBUS-G3H <1V
    Hi all, i would like to learn to repair pcb, i'm tring to repair a macbook air 1466 with mb 820-00165-A
    I got ppbus_g3h about 0,9-0,8V, fuse is ok,
    PP3V42_G3H present
    the only thing i can notice is a burn on the cable of the display
    What can i check ?
    thanks.
    Re: MacBook Air 820-00165-A PPBUS-G3H &lt;1V
    check voltages without anything else attached - only dc-in board. Measure resistance on ppbus_g3h.
      Thanks, 0,9V is without anything attached, i will check resistence
        Resistance to ground on ppbus_g3h is 600ohm
          Removed fuse F7140 still have low voltage on ppbus_g3h
          checked PPDCIN_G3H, 1,7V goes down to 0,8V
          PPDCIN_G3H_ISOL : 15V
          hope to find the sort :-)
            Not possible. PPDCIN_G3H_ISOL is derived from PPDCIN_G3H.
              Sorry, my mistake,
              PPDCIN_G3H = 15,04V and also PPDCIN_G3H_ISOL
              PPDCIN_G3H_INRUSH = 0,9V
              CHGR_SGATE_DIV = 0,9V
              PP5V1_CHGR_VDD = 5,14V
              PP5V1_CHGR_VDDP = 5,14V
                What about ACIN and DCIN of U7100? Resistance between pins 17/18 and between pins 27/28 of U7100?
                EDIT: and resistance between pins 26/27 of U7100 as well
                  CHGR_ACIN = 3,92 V
                  CHGR_DCIN = 14,72V
                  resistance between pins 17 and 18 is 3,4 ohm
                  resistance between pins 26 and 27 is 164,9 kohm
                    And between 27/28? If it's 20 ohms you can try replacing U7100.
                      Yes, between 27/28 of U7100 resistance is 20,1 ohms
                      can i use a new U7100 ?
                      I also have another board with fan that spins but not boot
