Got this sub woofer from storage but the blue led power not on. So i suspect something gone bad at the power board. Noticed a dual op amp 4558d jrc 0058t . Upon checking on google, vcc is at pin 8, ground at pin 4.
Also googling on those 3pcs 5 pin audio power amp tda2030al screwed to heat sink.
Pin 5 is power supply and ground at pin 3.
I saw the 230vac transformer output 12v thru the blue wires to the pcb. I wondered if it is safe to use my dmm and probe the above mentioned pins to check on live voltage.
The problem is since i am not able to find any schematic, i don't have any idea what voltage to expect. Can anyone help me on this and kindly suggest or give guidance.
Thank you.
Thank you.
