I have a plasma TV model # 50PA6500-UA that when the customer plugs it in, the screen flashes on and off and you can hear a relay on the power supply board continuously clicks on and off. I replaced the relay but the problem persisted. After further testing, I noticed that when the main board is disconnected from the power supply board the problem doesn't occur. Any tests or advice that could lead me to a conclusive board that I should replace would be very much appreciated.
50PA6500-UA Power board relay going insane!
Re: Power board relay going insane!
Originally posted by tvtimmy View PostUnplug the tv. Unplug the ldvs ribbon from the mainboard to the control board and put a piece of wire in the holes marked auto ext on the control board. Plug the tv back in and check if you have test patterns on the screen.
Do post #6. They had a lot of bad blue caps at that location. fixed a few PA series with that problem back in 2015...
See https://www.badcaps.net/forum/showth...t=38197&page=3Last edited by jjanssen7; 11-03-2020, 08:52 PM.
