flashes both eeproms u114 and u115, tv now boots and works great on all inputs, but can not tune in any tv channels ? ideas ?
celcus dled40125fhd
Re: celcus dled40125fhd
Maybe try that if you did not already: Switch on your digital box and/or TV.
Press Menu on the remote control.
Select the Setup or Installation option.
Select the 'First time installation' option (sometimes called 'Factory reset', 'Full retune' or 'Default settings').
Press OK if your equipment asks if you want to delete all your channels.
A repair kit. It's for the stick. Unzipped, put on stick fat32, press and hold the OK key on the remote control. Insert TV into the socket. Release the OK key when the stb LED flashes fast.Attached FilesLast edited by yokoono; 01-16-2020, 04:20 AM.
