Lg 55ls5700-tb
    Lg 55ls5700-tb
    All,
    Having an issue with the backlight of a family members Television.
    TV turns on fine and works fine. Around 2hrs into operation the backlights are shutdown. On the power supply board the LED in the board flashes 4 times. Then repeats.
    I have checked all outputs as per service manual and they are spot on. The LED+ GND tes points measures around 76v when operating, but once the backlight drops out it measures 71.3v.
    I originally thought it was a dry solder on the power board, but after replacing with a new board its still playing up. Faulty backlight LEDs?
    Any ideas?
    Thanks.
    Re: Lg 55ls5700-tb
    Turn down the backlights level in the OSD User menu to as low as you can and see if the backlights will stay on longer.
      Re: Lg 55ls5700-tb
      OK mate. I will give that a go.
        Re: Lg 55ls5700-tb
        OK. So the TV has been running for around 2 1/2 hours with the backlight set to minimum. Every other time it usually switched off the backlights around the 2hr mark. Where from here?
          Re: Lg 55ls5700-tb
          Looking like bad led/s in backlights.
            Re: Lg 55ls5700-tb
            Is there a method to follow to test the backlights?
              Re: Lg 55ls5700-tb
              Please upload the service manual and als the pictures of the whole backside of the TV showing all the board, and straight shot of the whole power supply board.
              Is this the exact board you have?
              https://www.shopjimmy.com/lg-eay6251...led-board.htm#
              Your LED panel has 12 LED strings. Do you have LED tester?
              Try checking each VC_x (LED Cathode return) pin to see if one are more are not the same as the rest. Notes: you need to turn off the dynamic contrast or any settings that will automatically adjust the Backlights zone control or backlights level.
                Re: Lg 55ls5700-tb
                OK mate. Will do.
                  Re: Lg 55ls5700-tb
                  OK
                  Here are the pictures and service manual. No I do not have a led tester. At this stage.
