Remove_SMM... UEFI.
    Re: Remove_SMM... UEFI.
    Originally posted by vignesharivuslm View Post
    t490, i7 8th gen cpu, nm-b901 patch pls, dxe autopatcher not work.
    Become a Badcaps supporter
    Thanks to all supporters.
      Originally posted by ak1_2004 View Post
      e595 !
      Autopatcher dont work !
        Originally posted by fraymaker View Post
        hello, i have a thinkpad x1 carbon 3rd gen. (20bs) it has a fingerprint lock in bios, if i skip fingerprint check it has a bios password. Don't really know more about the bios setting, since i cannot enter bios even in read-only mode. When i enter 3 incorrect passwords it just restarts. I patched the bios file and used ch341a to write it directly on the chip. I get 5 + 5 beeps and no display. After that, i wrote original bios and it's working the same as before (locked bios). I have attached original bios and patched bios. I think it might be me region lock can anyone help with it?
          Originally posted by hoaca388 View Post
          Dont work !
          if can you help me to edit manual this bios dump .thnx
            Dont work !
            if can you help me to edit manual this bios dump . i can pay $ to you !
            thx
            Hello, I think your problem is that your BIOS file does not contain any Intel firmware ME region.
            Please check it yourself with the ME Analyzer
            https://github.com/platomav/MEAnalyzer
              E595 AMD CPU Laptop
                E595 AMD CPU Laptop
                System with AMD cpu have no ME ( Intel Manager Engine )
                  Originally posted by Maxpower3 View Post
                  Update V3 !! (read above)
                  Only for Windows
                  Fix problem with python
                  Please Test and report
                  please update the link
                    Is there a solution for L14 gen 1 to remove the bios password?
                    https://www.badcaps.net/forum/showpo...postcount=1426
                    thx
                      Hi there you couldnt generate a key for me could yoou please. Hardware id is <2809280> i just geenerated this hardware id i and wont turn the compter off
                        @ronlater
                        The files are patched, so that you only have to press ENTER key to complete the unlock, no KEY is needed as far as I know... try.
                          It just said invalid key
                            Try to use the Auto-Patcher next time, so that the resulting patched bios files do not require a KEY.
                            Who patched your bios file? In order to know which algorithm to use. Provide a Hardware ID and I will provide you with the KEY, remember that BACKSPACE key do not work to correct a mistyped KEY.
                              Ok It was patched by someone from vinafix.Is there a tutorial on how to use the auto patcher. My hardware id is 7713780
                                (Hardware ID: 7713780)
                                The KEY is: 8369400
                                  It said invalid key
                                    Do you have a Hardware ID + matching KEY that you have used before?
                                      i have the original hardware id and the first key, but the computer sat for awhile and was unresponsive so i reboot it. original Hardware id 1809260 and original key 1369857. While the first id was on the screen the computer sat for too long became unresponsive so i rebooted then tried putting in the key i got not realizing that the id regenerates when rebooted
                                        Verify, the closest match I get is this one:
                                        (Hardware ID: 1809260)
                                        The KEY is (new-A): 1369856
                                        Post a new Hardware ID and wait for the KEY.
                                          1369857
                                          Enter and
                                          Press 2x space bar when asked. Turn off the computer.
                                          and restore your original bios . Done:
                                          thats what i got for the original key. do you think it could have been a typo
