SVHS Goodness
    SVHS Goodness
    So I picked up today for $6 an SVHS VCR, something I have been looking for in bargain bins for a long long time. It's been around ten years since the guy at Sears was gonna sell this to me on "sale" at $200, I offered him $100.
    In case you're curious, the model is HR-S3600U. I know JVCs are not the top pick of the litter but I checked inside, the caps are Japanese, and the picture this thing puts out is excellent.
    I also picked this camcorder up many months ago, but I need an adapter for it (The model I need is PV-A22). This is a Panasonic Omnimovie PV-S445D.
    Anyone also know where to get SVHS tapes?
    Re: SVHS Goodness
    Do you mean blank ones or precorded ones?
      Re: SVHS Goodness
      Blanks. I'm not aware of anyone mass-producing SVHS videos, wasn't it used mainly for personal videos?
        Re: SVHS Goodness
        how do they differ from regular tapes?
          Re: SVHS Goodness
          Higher resolution.
          Also OP, why not use DVD?
            Re: SVHS Goodness
            Oh this is for conversion. I figure if I'm doing a VHS to DVD rip, the SVHS VCR will give me a better picture. Also, with this VCR I can record "SVHS ET" which is SVHS to a normal tape. I tried it results are pretty good. Old school.
              Re: SVHS Goodness
              I've bought 3 $5 VCRs in the past year, and they were all fails.
              The first one worked for about a month. The other 2 were DOA. Annoying.
              I haven't seen an SVHS yet, I'd love to get one of those if I happen across a cheap one. But when I do, it probably won't work.
                Re: SVHS Goodness
                dont buy a vcr until you know where to get a new belt-kit, idler & pinch-roller.
                  Re: SVHS Goodness
                  Whatever you do, don't fall for that 'drill a hole' trick, as seen here:
                  http://www.technofileonline.com/text...persvhs90.html
                  SVHS tape is higher coercivity than 'normal' VHS tape. If you cheat and record the hotter, higher frequency, wider deviation with higher carrier freq signal onto regular tape, you're gonna have problems. It'll look minor at first- beading/overmod noise in high contrast areas, with partial self-erasure after the oversaturated domains 'neutralize' themselves.
                  VCR belt/pinch kits:
                  www.studiosoundelectronics.com
                  -Paul
                  Edit- way to bump an old thread!
                  "pokemon go... to hell!"
                  EOL it...
                  All style and no substance.
                  guilty,guilty,guilty,guilty!
                  guilty of being cheap-made!
                    Re: SVHS Goodness
                    Dead VCRs (and other discarded electronics) are a good source of various parts. In this case you get a few motors, gears, and miscellaneous mechanicals too.
                      Re: SVHS Goodness
                      SVHS came about in order to obtain a slightly better picture than VHS. SVHS is not a higher resolution picture even though certain advertising materials make that claim. The primary advantage is that the chroma and the video signals remain separated all the way to the tube, (assuming you have an SVHS CRT monitor). The system was intended to reduce chroma noise and crosstalk with the Y signal, and it did improve the picture slightly when used with the proper equipment. As far as your JVC SHVS machine, your main electronic issues will be the switching power supply. A bigger deal is worn parts in the transport and proper adjustment.
                      Is it plugged in?
                        Re: SVHS Goodness
                        The FM luma carrier on the tape is a higher frequency than non "S." We can deviate more, and still keep the LSB away from the 629 kHz color-under sub carrier.
                        More bandwidth and seperate Y/C.
                        EOL it...
