Dell Inspiron 1545 bios paasword
    my friend
    roberts
    08212-2
    48.4aq01.021
    #DP2NXJ1-595B
    reset help
    Re: Dell Inspiron 1545 bios paasword
    I don't think it was a clever idea to open up a new thread for a password, there are plenty of password threads you could have asked in, if you had searched, anyway enough said on that.
    your password is, l6i0lr53
    it is case sensitive, so enter as seen
    press enter or hold down control then press enter
    here is a link to the calculator for future use, http://bios-pw.org/
    good luck
      my friend
      invalid password
      How else do I solve it
        Originally posted by asliyucegsm View Post
        my friend
        invalid password
        you may need a USB QWERTY keyboard (US, UK etc)
        double check the service tag you gave us for errors (like the 1 being a l etc) also that you typed in the correct password, the first and fifth letter is a small l for larry, and the forth is a nought
        that password should definitely work for the 595B tags
        that's the best I can do for you
        good luck
          my friends solved
          new bios and short
          remove motherboard from you laptop.
          connect power and turn on.
          short G49 only one time.its shout down.
          remove power and assemble your laptop again
          Then go to bios by press F2.
            @asliyucegsm
            good ending, thanks for letting us know, that info will come in handy,
            there is another Dell you can do that too, in this thread, https://www.badcaps.net/forum/showth...ighlight=n5110
            I wonder how many more dells that can be done on
            good luck
              dell 1545
              roberts mb
              08212-2
              48.4AQ01.021
              BIOS
                Originally posted by skylaptopcare View Post
                dell 1545
                roberts mb
                08212-2
                48.4AQ01.021
                BIOS
                try
                  BIOS Dell 1545 ?
                  48.4AQ28.011
                  09224-1
                  DR1 DIS 512M MB
                    Originally posted by A1yn88 View Post
                    BIOS Dell 1545 ?
                    48.4AQ28.011
                    09224-1
                    DR1 DIS 512M MB
                    try the one i posted it s virgion bios
                      Thanks, but my laptop doesn't start at all with these bios.
                        what's your service tag
                          8qcxzj1
                            my friend
                            roberts
                            08212-2
                            48.4aq01.021
                            #DP2NXJ1-595B
                            reset help
                            100% ok edit site dell
