Resistor question
    Re: Resistor question
    Originally posted by Davi.p View Post
    test in ohm R903/4/5
    Ok I found them meter set at 20k
    R903 3.29 K
    R904 3.29k
    R905 3.2k
      Post 25.
      Originally posted by 1supertech View Post
      q207
      b&c 0.02
      c&e 0.00
      b&e 0.02
      q206
      b&c 0.01
      c&e 0.00
      b&e 0.02
      q203
      g&s 0.00
      g&d 0.02
      d&s 0.02
        supertech read what budm said, you have to dismount the 3 inverter transistors and retry..
          Q206
          B&C 0.L
          C&E 26.32
          E&B 26.55
          Q207
          B&C 0.L
          C&E 25.31
          E&B 25.92
          Q203
          G&D 0.L
          D&S 11.82
          S&G 0L
          I have no idea if these reading are any good but my dca55 shows no shorts
          numbers of each q203,q207,q206 readings were fluctuating I just picked the number it stayed on the longest.
          maybe I need a better multimeter .
            you need to say if the results are ohms kohms, volts or what
            also can you read the part numbers (numbers off the parts, not the board numbers
              Post 64 is all in ohms
              Q203 PU401 OR BE6A11
              Q207 D1805
              Q205 D1805
                The 3 resistors MAY be ok but you may have your zero s mixed up.
                They have on them 334 so should be 330kohms not 3.3kohms??
                I suppose you had better check them again but at least they are not open.
                I have been trying to get my head round something for a while - In your first post you say this monitor is an Acer 1906 and I have been looking at threads on that monitor to try and help us. Many things did not make sense and I am now wondering if your set it really an acer 1916 as there are very few hits showing this power supply with a 1906.
                I still think the 3 Qs are bad (less than 30ohms) If one of them is a double diode can you test it as a diode. ( Reversing the leads and advising the result
                in both directions)
                  the 3 resistors are marked "332", the 3 Q are transistor for sure because them are on the inverter area, i'm not usual testing them in ohm so i don't know if them are good..
                    SELLDOOR, and everyone thank you very much for trying to help me with this but I learned allot from you but I going to give up on this board. I buy non working monitors from recyclers maybe I will run into a Acer1906 with a cracked screen.
                      Ok - Sorry we couldnt fix it - better luck with the next one.
                        "Q206
                        B&C 0.L
                        C&E 26.32
                        E&B 26.55
                        Q207
                        B&C 0.L
                        C&E 25.31
                        E&B 25.92
                        Q203
                        G&D 0.L
                        D&S 11.82
                        S&G 0L"
                        "Post 64 is all in ohms
                        Q207 D1805
                        Q205 D1805"
                        That means they are bad.
                          You will never grow up if you give up at theese very basic steps, the next step is very easy, remove those 3 q , power up and see if led remains on.
                            We are getting close to the source of the problem based on the resistance readings of those transistors.
