Hello to all This is my first time posting.
I recieved a Dell E151FPb that the owner didn't want anymore due to "white screen" issue after the monitor would warm up a bit.
edit note* I forgot to mention that the original "white screen" issue the previous owner had was likely due to a desoldered joint on coil whose number I can't recall. There was talk of this issue in another forum, and indeed this same coil had the similar symptom on my power board.
I hastily opened the casing to see what could be at fault, and noticed the monitor used the "usual suspect" C5706/C5707 transistors, and two IRFU024N hexfets. Being naturally inclined towards laziness, I decided to do absolutely zero troubleshooting, and just change the above, along with a few filter capacitors.
I did not have IRFU024N hexfets, so I used two IRLZ34's, which have similar specs. In any event, the monitor turns on, but there are three new symptoms:
1) Top half (more like top 35%) of screen darker. (dying lamp?)
2) Monitor does not go to sleep (green led does not go amber when computer powered off)
3) Monitor does not power-off. When attempting to do so, LED shuts off, but you are left with "white screen", so I'm guessing the lamps are still drawing juice from discharge?
I have no idea what's wrong :\
Many thanks for your time and patience.
