Resistor question
    Re: Resistor question
    Check the voltage on CN902 with nothing else connected to the power supply board and see if you do get any reading. Are you hearing any ticking sound from the power supply board?
    No power no sounds
      There are 3-pin devices mounted on small heat sinks in the inverter circuit section, please take the RESISTANCE reading on 3 legs combination.
        Just wonder what you are using for ground when testing the socket?
        If you look on the back of the board you can see the bottom two pins on the socket are ground. So working as budm suggests with only the power supply connected, test on the back of the board with black probe on bottom pin
        then with meter on vDC20 test each pin on the socket with the red probe.
        While you are there put the red probe also onto each side of F902 and see if any voltage there.
          Power fluctuates on socket the same on each side of fuse F902
            there are 3-pin devices mounted on small heat sinks in the inverter circuit section, please take the resistance reading on 3 legs combination.
            q207
            b&c 0.02
            c&e 0.00
            b&e 0.02
            q206
            b&c 0.01
            c&e 0.00
            b&e 0.02
            q203
            g&s 0.00
            g&d 0.02
            d&s 0.02
              it fluctuates? you mean each pin reads a different voltage or just 1 pin?
                ok but you need to tell us what the voltage is on each pin eg
                pin1 5-7 fluctuating
                pin2 o
                pin3 9.1 -12.4 fluctuating and so on
                Fuse both sides 15v -17.3v fluctuating
                  q207
                  b&c 0.02
                  c&e 0.00
                  b&e 0.02
                  q206
                  b&c 0.01
                  c&e 0.00
                  b&e 0.02
                  q203
                  g&s 0.00
                  g&d 0.02
                  d&s 0.02
                  looks like they are all shorted - may have to take off and re test
                  one at a time.
                  can you post the part numbers
                    pin2 o
                    fuse both sides 15v -17.3v fluctuating
                    pin1 0
                    pin2 0
                    pin3 036-169
                      there are 8 pins on cn902 how do you only have 3 pins?
                        put multimeter on dc voltage and check each pin with red probe on pin and black on chassis
                          oops test power socket
                          will retest
                            are the pins listed on the board? if so list that next to the readings
                              pin2 o
                              Retest
                              PIN
                              1 3-67v
                              2 3-67v
                              3 3-67v
                              4 3-67v
                              5 3-67v
                              6 3-67v
                              7 3-67v
                              8 3-67v
                                one at a time.
                                All tested good no shorts on DCA55
                                  1 of them has to be a ground. how can you get the same voltage on every pin?
                                    I tested from ground on power socket to all pins CN902 fluctuates 3-67 v normally I don't get
                                    power to CN902 with mainboard connected
                                      q207
                                      b&c 0.02
                                      c&e 0.00
                                      b&e 0.02
                                      q206
                                      b&c 0.01
                                      c&e 0.00
                                      b&e 0.02
                                      q203
                                      g&s 0.00
                                      g&d 0.02
                                      d&s 0.02
                                      Are they in Ohms, K Ohms, M Ohms? They do not look good.
                                      The voltage readings of 67V can only be from using the wrong ground ref. point. You should use one of the negative leg of the filter caps on the secondary side as the ground ref.
                                        1- 0 k
                                        2- 0 k
                                        3- .99k-18.94k
                                        4- 0-.98k
                                        5- 23.5.98k
                                        6-4.91-5.30k
                                        7-0k
                                        8-0k
                                        all reading fluctuating except 0
                                        millimeter was set to 20k
                                          It looks to me that this is getting very muddled.
                                          1supertech - you must say if you are not sure what we are saying.
                                          I can only assume English is not your first language and you dont understand
                                          Or you dont understand the electronic terms or both?
                                          If you can confirm that we can make allowances and try and explain better
                                          what you have to do.
