OK I have been repairing monitors for 2 years as a hobby luckily all problem I have encountered, where bad capacitors, EEPROMS, transistors I am self taught by reading
all I can. Yes your right English is not my first language but I have been here 55 years
So basically understanding electronic terms can be a problem.
With meter on 20vdc plugged in power socket just with black probe on ground
I get a fluctuated reading of -0.00 thru -.001
While checking all pins with black on ground 1thru 8 is -0.00
fuse -0.00 both sides
On my meter minus is flashing with no power is this normal
I test a 12v battery and show 12v so I assume my multi meter is working
also tested my battery in my millimeter is ok.
in your picture of bottom side, watch in the primary side the small 8pin ic, to the left of it starts a row of 3 smd resistors like a train that goes to 1 pin of the transformer. If you want test also the voltage of the pin of the ic where them goes..
From the readings of those 3 devices, it looks to me that they are shorted out and cause the power supply to be in shut down mode, I would all 3 of them off the board and see if the DC will come back.
