Acer R241Y LED Monitor Horizontal lines
    I hope I can get some suggestions on what to look for before attempting to dismantle my monitor.
    I have the above model, manufactured in 2016 that has developed an annoying problem, every 4 seconds I get a row of horizontal thin lines connected by 3 vertical evenly spaced lines across the bottom 2 cm of the screen. It actually looks like an image of a ribbon cable. They stay on for 4 seconds and then disappear again, and it just cycles through this all the time.
    I've disconnected the inputs and tried it with another power supply (I have 2 of these monitors) but the problem still exists, if I do a screen shot the lines do not show up in the image, so I think I can safely assume it is the display that is the problem.any help would be much appreciated.
    Thanks in advance
    I don't why but the image keeps getting rotated 180 degrees when I upload it, so its actually the wrong way in the post.
