Request for Opinion on some broke Sony CRTs
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    I have the following monitors and they are all broke. I would like an opinion on whether the repair costs would be high or not. They are out of warranty so I would use a monitor repair shop.
    Sony G200 17" FD trinitron - doesnt power up, orange led only. Worked fine then that happened one day.
    Sony 15" Trinitron - screen was getting progressively dimmer now unusable
    Sony 17" Trinitron - was taking many tries to power up each day. Was powering up but not making the strong ping of the display initialising until after the 7th try when it would power up, the display would come up but wavy and then the display would appear ok and it would work fine. Now only gets the green led then a click and the orange led. Nothing else.
    any ideas which one(s) to take. I know it is difficult be give me some idea. Basically they are closing the store room at work so all broke stuff has to be either repaired or dumped.
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16956
    The first one... Does the amber LED blink or is it on constantly?
    The second one (15"), check for filament voltage on the CRT. It should be about 5 volts. If filament voltage is present, and the filaments light up, it sounds like the CRT may have bit the dust.
    The last one, sounds like flyback.
    I quit repairing monitors years ago, they're so throw-away today... However, there's always salvation for a good Trinitron!!
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • willawake
      Super Modulator
      • Nov 2003
      • 8457
      • Greece
      ah no i messed up, the FD trinitron is completely dead. Pity, that was my favourite monitor until I got the samsung 173p. Miss the DVDs on the FD though the sammy doesnt have the speed but it surpasses the FD for static images...hail PVA matrix . Now with sammy 710v's on sale (my new office monitor) not so much reason to resurrect the old stuff. but i could use another one or two lab monitors if it does not cost too much to fix the sonys. I guess the 15" is toast though.
      • cmonkey
        Sony Trinitron KV32FV27 Suddenly Dimmed
        by cmonkey
        A couple of days ago I finally got my hands on a locally sourced Trinitron and after lugging all 175 LBS home I gave it a good cleaning inside and out. The guy said it had been in a shed for 2 years, but the outside wasn't too bad. The inside was another story and while there was no evidence of mouse, it had certainly been kept in a VERY dirty home.
        I cleaned it to an acceptable level of grime, at least clean enough to where nothing would heat up from the dust insulation. I then tried it out and it worked!
        I'd say I had it on for about 15 minutes or so and then lugged...
        04-28-2023, 06:25 PM
      • motorahead
        Sony Trinitron (KV-20FV12) Vertical Deflection Stopped
        by motorahead
        Hi everyone, I've been troubleshooting my 20" Sony Trinitron (KV-20FV12) CRT after it failed to show a picture. The standby LED is blinking 4 times, which according to the service manual is a failed vertical deflection via the self-diagnostic check during power up.
        After getting the TV checked out by a technician and doing research on my own. The most obvious first step was to replace the IC502. I've done so with an exact NOS replacement with no luck. I've read a few suggestions to make sure the 12V supply to pin 2, but that voltage check would seem misleading? It seems if the...
        10-21-2023, 03:50 PM
      • ptcriserx3
        Sony trinitron crt bowed and side color issues
        by ptcriserx3
        Hi
        Ive got a vintage 2001 sony trinitron flat tube tv
        The image is slightly bowed and the left and right sides about 1-2in has fluctuating discoloration that comes and goes if i move or hit tv on sides
        See many images attached...
        Just windering if this is not fixable or something i can correct without getting too invloved
        Im trying to sell the tv
        06-17-2023, 07:27 PM
      • Carlos#2003%
        Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
        by Carlos#2003%
        Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
        02-15-2024, 07:52 PM
      • sickboy
        Strange CRT Fault (Sony Trinitron M1410U)
        by sickboy
        This is a CRT I sold a few months ago and it's came back with this weird issue. It's intermittent, but not a thermal fault, or tap sensitive - just completely random. The right side of the picture completely blanks out (picture is not shifted). The on screen display is unaffected though, so not a fault in the line section. Anyone seen anything like before in a CRT?
        11-10-2024, 05:02 AM
