dell motherboard 13283-1 power problem
    dell motherboard
    13283-1 board
    voltages of power connector (DC IN) very low, i think shorted. (no 19V)
    when disconnected from board power connector voltage ok 19v coming.
    help me to resolve this asap.
    after removing PU4402 or pr4402 resistor, voltage of dc in is ok but not power on the board i changed that mosfet and resistor but not worked help me asap.
    Last edited by piernov; 09-14-2020, 03:28 AM. Reason: issue will not be solved faster by making the text bigger…
    Re: dell motherboard 13283-1 power problem
    what is the Voltage on the PU4402 S D G , after test IC PU4404 pin 1 2 20 6 5 16 voltage , PSID_EC Voltage ?
      pu 4404
      pins
      1-0v
      2-19.4v
      5-0v
      6-0v
      16-0v
      20-0.361v
      pu4402
      s-19.4v
      d-19.64
      g-19.61
      pr 4402 not in the board when checking
        pu 4404
        pins
        1-0v
        2-19.4v
        5-0v
        6-0v
        16-0v
        20-0.361v
        pu4402
        s-19.4v
        d-19.64
        g-19.61
          Originally posted by chamalsb View Post
          pu 4404
          pins
          1-0v
          2-19.4v
          5-0v
          6-0v
          16-0v
          20-0.361v
          pu4402
          s-19.4v
          d-19.64
          g-19.61
          You have to follow & Understand the Basic before you start to change components, What is your 1st Mosfet & why is it not switching? As for the Schematic AMD you 1st Fet is P -channel the Gate voltage is too high for the gate pass , check out the Pic & update the voltage
            can't understand where to where check voltages
                https://ibb.co/RbV6srL
                https://ibb.co/nDcStCc
                  oh dear he we go again 1st clean you bord with isopropyl alcohol PU4404 IC count ant-clock wise pin 6 is connected with PR4407 it's Resister check the voltage on both side after put the multimeter Ohms with out any power test Ohms on pin 6 20 of PU4404 find out PQ4402 Dual N-channel mosfet test voltage of all pins uplode a cleair Pic again near the 1st Mosfet (is sitll The Vedda Village exist Mahiyanganaya )
                    YES Brother in Near to that place 25 KM from my town to Veddhas place come and visit call me +94717619176
                      Good I suppose you have not tested the points that I have highlighted
                        voltage at pr4404 pin 1 and 2
                          I have a similar problem to this, Does anyone know a good thread that teaches how to properly test mosfets? I am relatively new to board repair, I can replace parts fine, just don't know the correct way to test them
                            or does anyone know where i can by a PU4402 mosfet? are then interchangeable at all, or is this one limited to only being made at dell?
