Hello. Seeking advice on an A1706, appears to be 820-00923 logic board where:
a) Apple has replaced the display under warranty
b) Apple has replaced the keyboard under warranty
c) now the logic board is acting up with that it power up, display works, boots the logo and onboard SSD for a restore -> prompts for the language selection -> voice prompts can be heard -> if you leave it here, the computer will reboot into this cycle after a few minutes. If you select enter to continue, the busy circle will spin for a while and then reboot into the same cycle.
The logic board / computer is out of warranty and Apple wants $$$ to replace it.
d) No fan spin on either fan
e) Black CPU heatsink is toasty warm and measures @ 105 degrees F
f) coils L7410, L7420, L7430 are reading at 0 volts. This is concerning.
g) L7210, L7220, L7270 are showing voltages @ (varies) from 0.5 to 1.0x volts. Each is part of a 3-phase
Understand that many other voltages have not yet been inspected but the unit is mostly working.
h) the apple logo is solid upon boot but splits into many pieces before display text - much like a jigsaw puzzle - have never seen this before on macbooks
i) using an external SSD, booting with fan spin and reach a point with "Critical update fail" message (see attached).
Suggestions?
Suggestions?
