#1 | ||
Super Modulator
City & State: Αθήνα
![]() Quote:
#2 |
City & State: Durban
My Country: South Africa
![]() My NAD 372 has just blown one of its caps as described above..
The amp is well ventilated but i think it was a power surge that made it commit suicide. Non the less, please could others share if they have had the same problem and what caps they have chosen to replace the originals. I am currently looking @ Panasonic for the main caps and while I am at it will replace all the caps for the power stage and then move on to replacing "all" the caps on the board at a later date.. Any advise in this regard would be greatly appreciated. |
#3 |
City & State: Canada
![]() I don't know what the original cap value is, but if it is 85C, then try to get at least a 105C and maybe there are some 125C caps?
--- begin sig file --- If you are new to this forum, we can help a lot more if you please post clear focused pictures (max resolution 2000x2000 and 2MB) of your boards using the manage attachments button so they are hosted here. Information and picture clarity compositions should look like this post. We respectfully ask that you make some time and effort to read some of the guides available for basic troubleshooting. After you have read through them, then ask clarification questions or report your findings. Please do not post inline and offsite as they slow down the loading of pages. --- end sig file --- |
#4 |
#5 |
City & State: Rockhampton, Queensland, Australia
My Country: Australia
Line Voltage: 240VAC 50Hz
I'm a: Hobbyist
![]() Welcome, Hyltz!
On these large NAD-branded capacitors, I see the Chinese "CD" series on them - and I have no reliable way of finding out their ripple current and lifetime. I still wonder why non-premium components turn up in premium-brand audio equipment...
My first choice in quality Japanese electrolytics is Nippon Chemi-Con, which has been in business since 1931... the quality of electronics is dependent on the quality of the electrolytics. |
#6 |
City & State: dayton ohio
My Country: U.S.A!
Line Voltage: 12vdc,120/240vac,480vac 3ph on my bench
![]() i think that series designation was stolen from cornell-dubiler.
its so common now as to be meaningless. i would get the lowest esr/highest ripple rating that will fit and even go up a range on voltage.if the empty pads are paralell with one from each group one can up the voltage even at a lower capacitance and add one at the blank. 1 group is for the + supply the other for the -. will mfrs ever stop putting junk parts in premium gear? probably not since those on forums of this nature are a minority and most sheeple dont do much research into this sort of thing. would still be interested to know who made the parts and how close they are to the edge. |
#7 |
Capaholic
City & State: Trenton, NJ
Line Voltage: 240/120V 60Hz
I'm a: Hardcore Geek
![]() Interesting pics there!
![]() I bet the main power rails run at like 70-something volts, no wonder why they pop when the mains voltage is high! Also, the CDxxx series thing makes a bell go off in my head - cheapo capacitors... the other capacitors in the amp look very cheap too (lame printing/marking quality, and poor plastic sleeve shrinkage)
Muh-soggy-knee |
#8 | |
City & State: NJ
Line Voltage: 120VAC 60Hz
![]() Quote:
The extra unpopulated spots on the board allow you some upgradabillity. Removing all 4 10,000uF 80V caps, and replacing them with 6 8200uF 100V caps, means you never have to worry about overvolting them again, plus you get a little increase in capacitance. Digikey has these: http://www.digikey.com/product-detai...0651-ND/272791 Panasonic T-HA series, 105 deg., massive 5A ripple rating, 35MM diam. Problem is these are 4 terminal, so check the data sheet to see if they will fit, looks like the board has extra holes for 4 pin caps, but they may not line up correctly. They' also 80MM high, you didn't mention how high the originals are. |
#9 |
![]() Hi Guys.
Many thanks for the feedback and suggestions. LLLlllou : the current caps are 4 pin, so they should be perfect, thanks very much for the link. I will have a word with my "electronic guru" this side and see what he thinks. Will post some pics of the upgrade and let you guys know what we decide to go with. |
#10 |
City & State: Ft Worth Texas
Line Voltage: 120vac60Hz
![]() Old thread and my first post here so hi to all. .... I just purchased (waiting on USPS) a NAD C272 amp serial# H4XC27204475. How can I find out what year this one is????????? I read this thread about the "cap mod"
![]() Thanks Louis |
#11 |
![]() Yeah, I know ... zombie thread.
![]() I restore vintage amps and receivers and I just finished another not-so-vintage C372. Here are my findings regarding capacitor/reliability issues with these units. * the PCB layout fosters caps prematurely failing. If you notice the red arrows to the right of the transformer...that's the PS regulation stage. If you look closely, you can see where I'd added an aluminum heat sink on top of the factory heat sink (courtesy of JB Weld and yes, JB Weld transfers heat). Those heat sinks get glaringly hot! ...and there are caps right next to them. If caps fail, it can cascade to active parts (like transistors) and you wind up with a mess. The regulation stage is also below the right channel amplifier board and since heat rises, this are other considerations when rebuilding these units. On the back side of a couple of the red-arrowed heat sinks, there are some electrolytic caps. I've chosen to mount them at a 90 degree angle to the board so they're away from the heat. And one more heat-generating area are those four wirewound resistors at the top of the amplifier boards. Those get silly hot as well! The factory calls for 3W rated resistors in those holes, but for more heat dissipation, I'd replaced them with a 5W rating. * the factory caps do not appear to be what one might consider, top drawer name brand, though they are NAD branded. This is usually an accounting decision and if you want to bring a piece of gear to market at a competitive price point, concessions may have to be made in manufacturing. Rail voltages to the amp boards on the C372 are +/-68VDC. Even with a 10% variance over spec, the factory 80V rated main filter caps are still within operating parameters. NAD had a TSB (technical service bulletin) specifying adding wire in parallel with the PCB traces for the main filter caps to mitigate resistance-related heat failure issues for those caps. I'm of the opinion that the failure mode for the main filter caps wasn't PCB trace resistance and attendant heat, rather the deficient amount of electrolyte in the caps dried out and POOF! Regarding cap failure close to the regulation stage -- which is actually more prevalent -- it's obvious the cap failures there are heat related. What would I have done differently to address heat/capacitor related issues? For starters, I would've mounted the toroidal transformer upright, which would allow for more available PCB real estate to spread out heat generating components. I would've mounted the amp board heat sinks externally for better convection, not under the cover and I would've spent another $50 (or less) on quality caps, then raised the retail price $100. Win-win. The design of NAD gear is well thought out, but implementation of it is lacking with this vintage. fwiw... |
Thread Tools | |
Display Modes | |
