Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Laptops, Tablets, and Mobile Devices > BIOS Requests ONLY!
Old 05-17-2022, 10:26 AM   #181
kevingill
kevingill's Avatar
City & State: Lancs
My Country: England
I'm a: Hobbyist Tech
Default Re: T2 Chip Programmer Tool
Originally Posted by gugbobgug View Post
and it still works ? today ?
Yes, once it’s tied to your Apple ID, all updates go through and it works fine.
kevingill is offline
Old 05-19-2022, 06:07 PM   #182
ugamazing
City & State: georgia
My Country: usa
Hey guys, I just found this thread. I am up for helping in any way I can with regards to pulling any dumps from any boards needed. I have basically every model of T2-based Apple laptop logic board, with as many as 20-30 iCloud locked of some models. I've been setting them aside in hopes an activation lock bypass/removal that's permanent comes about.
I miss the old days of using a headless Raspberry Pi to remove locks. These damn T2 chips are really aggravating us.
Thanks for all the work you guys do and progress you make. I've not checked in too much on the status of a lock removal, but am ever-hopeful.
ugamazing is offline
Old 05-22-2022, 02:06 PM   #183
tungtuoitinh
City & State: Hanoi
My Country: Vietnam
and with monterey does it work ?
i think apple patched this
Originally Posted by Pedro147 View Post
I'm wondering, if in recovery mode "starting internet recovery" is shown under the image of the earth, then surely it can't be bypassed, right? is there any chance for this new bridgeOS case?
In my case,My Macbook air 2018 can't boot into macOS , it's stuck in select wifi to recovery, but i forgot password,it hang on at" activation lock" ,so i can't check version bridgeOS
And the last question, can I use hackintosh device with usb A to use bypass tool?
tungtuoitinh is offline
Old 05-24-2022, 06:26 AM   #184
Rickkap
City & State: Scotland
My Country: UK
I've had the T203 for some time now and after the update it stopped working, I also noticed that Union stopped selling it so i presumed that there was no way for getting round this anymore. I then came across the Stephen's guide but it was too late for me as i've already config 2 after trying to replace the serial number. So my question is there anyway round this or do i have to wait until a fix? I also tried Check8 but they don't support the A2141 probably since i stupidly used config 2.
Rickkap is offline
Old 05-25-2022, 03:29 PM   #185
sinaps1
City & State: Shkoder
My Country: Albania
Never thought would find something lik this support forum so much dettailed in everything! Congrats to all the staff.
I got a A1932 T2 model activation locked that is stuck in only intermet recovery.
I tried even in DFU mode with checkm8 soft to try if it is identified but without success.
The Comand-R combination or any except the DFU doesnt work.
By any chanche is any possibility from DFU to get the OS version or the iBridge OS version?
I want to figure out if has been updated to the latest version, my colleague kept connecting with wifi in recovery mode.. and from researches found out that if it is locked is stuck in internet recovery mode only.
Any suggestion to do any verificarion in this state. I am pretty sure if I programm the T2 ROM will stuck in DFU mode bricked.
sinaps1 is offline
Old 05-25-2022, 09:49 PM   #186
tungtuoitinh
City & State: Hanoi
My Country: Vietnam
you should check the previous pages, it have image how to check old bridgeOS vs new bridgeOS ( with new bridgeOS have "start internet recovery") after connect wifi
Old 05-25-2022, 11:50 PM   #187
sinaps1
My Country: Albania
Yes I have a new bridgeos but my previus question was regarding the versions. If this macbook is at latest version or something a bit earlier? So at least I will know when something comes out for the version I have.
sinaps1 is offline
Old 05-26-2022, 12:27 AM   #188
tungtuoitinh
City & State: Hanoi
My Country: Vietnam
I think you should dump t2 chip rom and check iboot version, im not sure is that true, so i need comfrim from others
Old 05-27-2022, 04:49 PM   #189
siddiq
My Country: Ghana
Line Voltage: 220VAC 59Hz
Yes, checking iBoot in the dump works..
siddiq is offline
Old 05-30-2022, 05:43 AM   #190
sinaps1
My Country: Albania
Found it. is a version iboot-7459 and I guess is updated to the last one.
I am not sure if I re-programm the ROM with an older version will cause the Macbook fail to boot at all.
Did anyone tried to flash the T2 ROM with older Bridge OS after it was updated?
After I changed the serial number on the same .BIN file of the ROM it is not able to contact the APPLE server.. seems like the contact POST method is tied to the Serial number in the ROM.
The serial Number was checked online if it was available and correct.
P.S. Still testing and digging we will find one way!!
sinaps1 is offline
Old 05-30-2022, 05:51 AM   #191
kevingill
kevingill's Avatar
City & State: Lancs
My Country: England
There are a few ROM dumps on this thread.
Can you compare your ROM with another posted here?
I'm not sure what the differences are either.
Old 05-30-2022, 06:38 AM   #192
sinaps1
My Country: Albania
There are a lot of differences, I tried to compare the A1932 that is the model I have!
The files are very different, and also the Boot sequence is different as it is not declared in the files that are here, instead the original one have some boot sequences inside. Because of this I asked if someone tried with the latest BridgeOS to rewrite the old one. Sincerely I have to unsoldering and soldering again the chip and then retry the bypass/activation.. before going through all the work and risking a board damage thought to ask if someone tried before.
Any suggestion for a software to decompile the .BIN files to something more understandable? I tried some software found online but without success!
sinaps1 is offline
Old 05-30-2022, 07:57 AM   #193
smzlwan223
City & State: 广东省广州市
My Country: 中国
Line Voltage: 220v
[QUOTE=sinaps1;1137421]Found it. is a version iboot-7459 and I guess is updated to the last one.
P.
smzlwan223 is offline
Old 05-30-2022, 08:00 AM   #194
smzlwan223
My Country: 中国
Line Voltage: 220v
I have an A1932, did the following experiment, 1, try to read the Rom to the latest version of the ROM im4p.. Illb .. Iboot-7459.101.2... Change it to the old jailbreak version number, M4P. Illb .. Iboot-6723.80. 9, change the inside data, Swipe Rom, power test, found that the computer can not start, feeling ROM IC is not good welding, welding a few times the same effect, 2. Finally, the original backup ROM data brush to write in, the computer can boot, the current test through this experiment, came to the need to verify before boot, t 2, Rom version, so I went on to do the second experiment, or the Rom to jailbreak version number, then connect to the computer to fix T2, wait for the computer to turn on, see if it can jailbreak, the result, or has failed, and then, remove the ROM, see again to fix T2 in the process of T2, the ROM version number has changed back to the latest version number, the result of the experiment, is, the version number of t-2rom data is, the old version number, through the experiment, one point is that the version number of the Rom, is not the basic data of his jailbreak, I do not understand the software very well, I hope you friends, have a good plan, I can do the experiment test, that's all I have so far.
Old 05-30-2022, 08:02 AM   #195
smzlwan223
My Country: 中国
Line Voltage: 220v
Check to see if the ROM version number was changed back to the latest version number in the process of fixing t 2. The result of the experiment is that the version number of the t 2 Rom data is the old version number. The experiment shows that the ROM version number is not the fundamental data for his jailbreak, my software is not very understand, hope you friends, there is no good program, I can do experimental testing, at present my inspiration only these.
Old 05-30-2022, 09:01 AM   #196
curiositymaster
City & State: Lagos
My Country: Nigeria
If you change the S/N of a T2 device, it will not pass the activation process as it won't be able to march the serial number with the bluetooth and wifi address.
curiositymaster is offline
Old 05-31-2022, 12:59 AM   #197
Stephen
Meow Meow MEOW!
Stephen's Avatar
City & State: USA 🇺🇸
My Country: United States
Line Voltage: 120VAC 60hz
I'm a: Hardcore Geek
Incorrect. MDM devices are the only devices you can change the serial number on T2 chips without issue. If it fails to activate on the server, the T2 chip itself was already activated and has the original iCloud and SN tied to the device.
MEOWING IN THE IMPOSSIBLE UNIVERSE!
Stephen is offline
Old 06-03-2022, 10:28 AM   #198
newmac
City & State: Manila
My Country: Phillippines
Can i use Mina T2 rom bin file to manually flash the T2 rom? Mine doesnt have a icloud lock it just wont restore using apple configurator. From what i know if i use the Mina bin files my serial number would be changed also would that be a issue?
newmac is offline
Old 06-03-2022, 04:51 PM   #199
heatorious
City & State: CA
Do you get a error when you try to restore?
heatorious is offline
Old 06-03-2022, 09:38 PM   #200
newmac
Error i get is Unexpected device state 'DFU' expected 'Recovery' [com.apple.MobileDevice.Restore - 0xFAE (4014)]
all of T2 standby power is present.
newmac is offline
Closed Thread
Badcaps.net Technical Forums © 2003 - 2023
Copyright ©2000 - 2023, Jelsoft Enterprises Ltd.
