#101 |
City & State: Hanoi
My Country: Vietnam
![]() Hi guys, something happened to my last effort and I want to ask if anybody has ecountered.
The device is A2159, appears to be activation lock. I tried with checkm8 to check if it was possible to JB, it did, then I proceeded to unlock with Mina tools. Then I got to Recovery normally, no erase mac option available so I just erase the hard drive and reinstall big sur. Afterwards, I check then it was a 11.6.2 BS and the bridge is already been updated to 19.16.14243. This is the part I couldn't understand how it got there. Therefore, it is not possible to access recover with Command R anymore (EFI locked). So anybody could kindly explain how it got update to the latest BridgeOS? And I can no longer access to jailbreak anymore... |
#102 |
City & State: Hanoi
My Country: Vietnam
![]() I kinda get it, I was unable to JB it the 2nd time so I got to revive, then it boot to OS perfectly but the Recovery might be blocked forever.
#103 |
Banned
City & State: Planet EARTH
My Country: Pakistan
Line Voltage: Very High ;)
![]() Recovery is not blocked but the jailbreak is not possible anymore for now at least publicly
#104 |
City & State: Hanoi
My Country: Vietnam
#105 |
TrumanHW
City & State: Los Angeles
My Country: United States
Line Voltage: 120VAC 60Hz
![]() You a MacOS user ... ? Able to read CH341x (ROMs) via MacOS ..?
If not, I finally figured out how (after 7 years) and can help (free obviously) As far as dealing with T2 (Intel + M1) ... I have: •*T203 •*Medusa 2.6 / 2.7 / 3.1 •*DS809 •*RT809F + Level Shifter I'm determined to figure iC locked + MDM issue (intel + M1) asap. Back to reading the remainder of this thread) |
#106 | |
TrumanHW
![]() Quote:
Have T203 – just haven't gotten that far yet. Do you know how to read ROM (bin) off programmers using MacOS ..? I figured it out finally, so if that'd help anyone LMK and I'll post instructions. |
#107 |
TrumanHW
![]() Fixing [ONLY] the MDM management issue can be done via T2's ROM (SN): •*Desolder ROM •*Dump ROM BIN •*Find SN: after string mNrS THE QUESTION: Does ONLY eliminating MDM from T2 (Intel obviously) require steps beyond modifying the SN? Exemplars of my preferred character-revision: - C02 --> CO2 ...or... C02 --> C0Z ... 6 --> G ... G --> Q - Retain the letter-qty - Validate: Fsys @ 0x590000 ... via Medusa v2.7 (SO convenient!!!) IS a valid SN FORMAT (naming convention) now required? If so, can we: - Could we not change the WEEK of mfr to 53..? - Reuse a SN that was made in one country-code (Czech?) for China? - Reuse a SN from a unit which is no longer reparable? - Is there something analogous to the 0x590000 ..? Thanks!!! [/SIZE][/B]IE, following Stephen's STICKIED: T2 Unlocking Method (Hardware) (Obviously all other info posted stands + I already have the T203) •*Pkg kind: 25-series SPI ROM •*Pkg size: 3x4mm (smaller than ≤ 2017 ROM) •*ROM volt: 1.8v (Requires a 'level shifter' to use a CH341a) •*Simple: T203 = CH341a with integral 1.8v level shifter + 3x4mm fixture. |
#108 |
Banned
#109 |
TrumanHW
![]() Cool, would you be willing to provide a copy of the SW which came with the T200 ..? I'm thinking the only difference between the T200 and T203 is the software, no ...? PS, You can read a CH341x on MacOS (as can the T203, - also a CH341a) |
#110 | |||
City & State: Canberra ACT
My Country: Australia
Line Voltage: PPBUS_G3H
![]() So I see that Stephen's new thread got shut down mainly because of the childish antics of one new member. Why do people have to destroy things to satisfy their own fragile egos?
![]() Quote:
![]() Last edited by Pedro147; 04-08-2022 at 10:55 PM.. |
#111 |
City & State: N/A
My Country: n/a
Line Voltage: 220
![]() hi! t203 with standart serial number is not work anymore? i tried mina chk8m devteam all this services have one data base. database used serial number but now t2 chip id.(((
#112 |
TrumanHW
![]() I'm not sure if it's old news or not, but I had looked for a USB driver for MacOS so I didn't have to use a damned PC to Read / Write ROM .bin files ...
I'm using an application? I think it's an app, anyway, a CLI app (via HomeBrew): FlashROM (.org if you want to read about it) ... Code:
SERIAL -to- USB - CH341 ROM (MacOS): Install xcode: xcode-select --install Relocate xcode: sudo xcode-select --switch /Library/Developer/CommandLineTools Install HomeBrew: /bin/bash -c "$(curl -fsSL https://raw.githubusercontent.com/Homebrew/install/HEAD/install.sh)" Install cask: brew install cask Install Ruby: brew install ruby Install FlashRom:** brew install flashrom List Programmers: sudo flashrom --help Verify reader: sudo flashrom -p ch341a_spi ROM Read: sudo flashrom -p ch341a_spi -r <name.bin> (defaults location ~ ) ROM Write: sudo flashrom -p ch341a_spi -w <name.bin> (defaults location ~ ) In ADDITION to FlashROM ... perhaps you'd also: Code:
Install MiniPro brew install minipro Obviously if you already have HomeBrew, XCode Tools, Ruby, etc., installed, you'll just be reminded of that if you attempt to re-install them. I can PM you a link to my Paste Bin of the commands if preferred. FlashROM work with 11 different USB Programmers (listed below): - dummy - ft2232_spi - serprog - buspirate_spi - dediprog - developerbox - pony_spi - usbblaster_spi - pickit2_spi - ch341a_spi - digilent_spi - stlinkv3_spi Attached image shows the command used to Read via my CH341a Pending which $PROGRAMMER you're using, just sub the above 'term' for the corresponding model you have. Hope that's what you thought I meant; I feel stupid now, learning about two different USB to Serial Programmers which have CLI (Bash) applications that obviate the use of a fcuking MISERALBE ass Windows-PC for a Mac ... and worse..? The only damned application that controls the CH341 R&W on a PC has a HORRIBLE HEX / ASCII editor. I'm literally ELATED to have found a solution ... for 8 fcuking YEARS I had repeatedly tried the "DRIVER" that FTDI put out for the CH341 ... with every version of MacOS possible, none-of-which worked! But this !?? In 2-seconds ... and it's been VERY reliable. Part of why I love MacOS is for things like, 'Scroll to Zoom' System Preferences --> Accessibility --> Zoom Check Mark "Use scroll gesture with modifier key to zoom: ^Control" This way, whatever I'm working on I can zoom in on in a fraction of a sec. INSTANTLY optimizing my display's working-area for exactly what I'm doing. When COMPARING CODE !?? Of COURSE it's preferable. Hell, even when using PC-3000..? I STILL prefer using TeamViewer over LAN bc... I can zoom in. There's nothing on a PC that's even close to the "scroll to zoom" feature ... and even though with glasses my vision's fine, close up I just make fewer mistakes of every sort. Last edited by TrumanHW; 04-09-2022 at 09:42 PM.. |
#113 | |
TrumanHW
![]() Quote:
I feel CERTAIN you know this already ... But those 4 digits ARE what define the model-specs. First 2 (C0) = mfr location... Last 4 (Right to Left) = Model... Example: C02SJ0R2G8WN C02 - made in china SJ0R2 - Date-Code + [Unique-Identifier] G8WN - MODEL I would've thought changing SJ0R2 to 2JOR2 or SJORS or 2J0RS ...etc ... would at least preserve the machine identity. If you insist on changing the last digits ... there is still a file in the OS you install which lists the machine identities ... and you could change that (at least on older OS). |
#114 |
Meow Meow MEOW!
City & State: USA 🇺🇸
Line Voltage: 120VAC 60hz
I'm a: Hardcore Geek
![]() I usually just change the last digit. In most cases
MEOWING IN THE IMPOSSIBLE UNIVERSE! |
#115 |
![]() Thanks for the comprehensive reply and I'll have a look and see if I can get a handle on it sometime. Appreciate the effort TrumanHW
#116 | |
City & State: Lagos
My Country: Nigeria
![]() Quote:
You're spot on mate |
#117 |
#118 |
City & State: ibaraki
My Country: nhật bản
![]() please help me icloud can't open macbook air A1932 EMC 3184
#119 |
![]() i think the same as you
#120 |
Please do not encourage this guy as he is trying to sell files that are available from others here for free. We don't want this thread shut down like the last one was because of stuff like this. Last edited by SMDFlea; 06-29-2022 at 04:15 AM.. |
Thread Tools | |
Display Modes | |
