Lenovo V130-15IKB bios dump
    Re: Lenovo V130-15IKB bios dump
    Originally posted by aminealae View Post
    turn on but no display
    Try again
    Become a Badcaps supporter
    Thanks to all supporters.
      Originally posted by hoaca388 View Post
      Try again
      nothing no display
        nothing no display
        Find other issue.
          Find other issue.
          but why when i flash it by dump on post 11 it work normal one time after reboot give me no display
            I don't know, if the problem is because bios, there are only 2 states: working or not working, there can't be such a flickering phenomenon. Try replacing the bios chip with a new one and see how it works.
              ok i have mx25l6473f i can replace it by mx25l6406e
                I'm not sure. You check their data sheet to see if they are similar. voltage for example.
                  Is there any chance to get some old bios .exe update file V130-15IKB?
                  I upgrade my bios to newest from lenovo homepage (8vcn30ww.exe) and it dosen't show screen after windows turn it off. And when I restart or turn it off/on, it dosen't show post screen. Few seconds are black screen and then immediately windows
                      thanks
                        anyione can help me on my unit, It has a bios issue but after I flash the bios the unit is normal again it has external display ok but in the internal lcd have no display, lcdvcc and backlight input voltage 8.5 is present but the rest is missing
                          This is the "BIOS Requests ONLY!" sub-forum. Please start a new thread in the main laptop forum -> https://www.badcaps.net/forum/forumdisplay.php?f=23
                            The unit is the same unit model sir? the unit now is alive and have display on external but non in the lcd in start up, the lcd displays only when it enters or load the OS
                              here is my back up bios
                                Re: Lenovo bios V330-15IKB
                                try this older version .
                                Thank you very much SMDFlea..it works perfectly bios 8VCN28WW ME_CLEAN.zip
                                  Can someone please unlock the Bios For me, Its lenovo V130-15IKB, thanks In Advance.
                                    Your bios version is 8VCN**WW ,use a bios from this thread, copy your DMI from your backup to the new bios using a hex editor,and the password will be gone
                                    HxD hex editor https://mh-nexus.de/en/hxd/
                                      Sorry no Clue, Can you recommend any tutorial?
                                        You can follow this one - https://www.badcaps.net/forum/showthread.php?t=98038 ,if you follow that to the end then you`ll have no problem with this V130-15IKB DMI
                                        See attached pictures for the V130-15IKB DMI off-sets -start and end points to enter into HxD
                                          I have downloaded the file from the lenovo website and trying to convert it via innoextract but its not converting the file. the cmd open and closeses after 1 second whereas no file is produced.
