DA0ZQFMB6F0 REV F no power
    Hope someone can help me unit has no power but it has 3v and 5v connection but missing 3v ec.
    VCCRTC - 3V
    RTC_RST#2.9V
    RTC_TEST# 2.9V
    +3VPCU - 3.3V PMW SIGNALS OK
    +5VPCU - 5V PMW OK
    SYS_HWPG - 0V
    NBSWON# - 3.3V
    S5_ON - 0V
    +5V_S5 - 0V
    +3V_S5 - 0V
    VNN_ON - 0V
    EC_PWROK - 0V
    +3V_C - 0V
    Attched schem and boardview
    Re: DA0ZQFMB6F0 REV F no power
    Pu6 - 1,2,6,7 - 3.3v
    3- 0v
    4- 5.1v
    5- 0v
    8,9 - 0v
    10- 0v
    12- 0v
    13,14 - 0v
      Hi
      Check PU7 mesuremants
        Originally posted by mielta View Post
        hi
        check pu7 mesuremants
        pin
        1- 6.72v
        2,3,4,5 -19v
        6,19,20 -3.3v
        7,8,1 - gnd
        9- 3.0v
        10,16,15,- nc
        11- 4.5v
        12-3.3v
        13 - 0.6v
        14- 3.3v
        17 - 3.3v
          Check PR30 at Page 22
          and search the PDF at 680_LDO and than check the way to +3V_LDO_EC
            680_LDO -3.3v
            d17 - 3.3v +3V_LDO_EC
              pr30 no stuff
              c417 pin 1
                check pin 26/50 from EC chip (IT8987E)
                  pin 26 is 3.3v
                    than you have EC power in first post you wrote you miss EC power
                    check Pin 107 and 112 from EC chip
                      107-3.3v
                      pin 112- 0v
                      thank you also sir
                        pin 112 must be 3,3v when you press Powerbutton
                          3.3v and goes to zero. Taking only 33mAmp on supply then goes 0
                            you can try flashing EC Chip you find it in Biossection
                              Ok I would Try it sir
                                EC_PWROK- 0v same after flashing bin and ec
                                  Pin 119 on EC Chip susb# when you switch Powerbutton on
                                    Nothings happens sir 0v
                                      unit now doesnt takes any amps if power is pressed
                                        maybe a bad sio chip?
