HP EliteBook 1050 G1
    Hello. Need a dump BIOS from a working laptop HP EliteBook 1050 G1. Thank you.
    Re: HP EliteBook 1050 G1
    post the backup copy of the original laptop bios and the motherboard model.
      Hello, peste. Motherboard model: DAOXW1MBAI1 REV: I
        the bios is corrupt and I can't clean it .. maybe someone who has this bios will post it ..
          Thanks for trying. I also failed to clean my native firmware, so I need a working one to build my native firmware.
            fixed. try it and give feedback .
              Hello, SMDFlea. Your firmware is working, everything is fine. Many thanks.
              PS: for those who want to use the firmware data, be careful they have a BIOS password.
                hp 1050 g1 bios
                hello everyone . i have problem to program bios .
                so i was flashed bios before successful but this time im really struggling with bios chip from hp 1050 g1 . so I reeded it saved backup copy and then was erase the chip but thing is that its doing that so quick and after if check if its empty i get error and i dont know what to do . its read the chip but i think not fully as should be and dont clean it as well as should be !
                and if i try to program it it works but when solder it back now laptop wont turn on .
                sorry if i ask any stupid questions but im not professional just learning by my self .
                chip name is MXIC MX25L25673GZ41 32mbyte
                programmer - ch341a
                software what i used was neoprogrammer v2.2.0.10
                  Re: hp 1050 g1 bios
                  Try with other program such as Colibri, AsProgrammer or Flashrom ( Linux )..
                  Become a Badcaps supporter
                  Thanks to all supporters.
                    Re: hp 1050 g1 bios
                    Thing is that I tried already with asprogrammer , i never worked with linux flashrom but i tried too with flashrom but thing is that when i install flashrom on linux its show some error so i was think i will do better then from programs which i know and worked before .
                    Can be a problem because of wrong adapter because? im using Sop clip or how it calls . But its detect chip everything looks like it works . Idk maybe its programms a bit different way not like normal bios? Because i saw videos on youtube there guys just read it don't clean and straight away flash new bios
                      Re: hp 1050 g1 bios
                      With CH341A you should not use clamps.
                        Guys can you tell me please is ch341a programmer is compatible with 32mb 256bit wson8 chips ? Or i need other programmer to flash bios ?
                          hp 1050 g1 bios needed
                          hello. can someone give me fully working bios for hp 1050 g1 DA0XW1MBAI1 REV1
                          16MB
                          AND
                          32MB PLEASE !!!!!!!!!!!!!!!!!!
                            Re: hp 1050 g1 bios needed
                            Post your corrupt bios file and serial number.
                              thats the 32 mb bios file .
                              serial number 5cd9418fth
                                HP EliteBook 1050 G1 Base Model Notebook PC
                                  Maybe you know why its show this kinda error ?
                                    So i sorted out everything. Bios is working . Many thanks . But there is small problem , its takes around 40 sec to turn on , both fans spins and black screen long time and after its show hp logo and then everything is ok
                                      Clean the ME firmware https://www.badcaps.net/forum/showpo...41&postcount=3
                                        Elitebook 1050 G1 BIOS Issues
                                        I backed up the main bios from my 1050 G1 with CH341 clip and i believe it's damaged. I was just trying to remove password from BIOS. Now every time I try a file it just blinks caps lock and power button LED
                                        If someone can try to clean the crashed BIN I will be forever grateful.
                                        Thanks so much
                                        Serial # is 5CD9251STV
                                        Last edited by Vesko356; 04-30-2023, 03:57 PM. Reason: Merging posts. AGAIN! It looks like the EDIT button has become invisible!!
