Badcaps.net Forum
Go Back   Badcaps Forums > Motherboards with Bad Capacitors > All Others Motherboards
Thread Tools Display Modes
Old 04-23-2015, 09:20 PM   #21
jesscat606
City & State: Xenia, OH
My Country: USA
Line Voltage: 120VAC 60Hz
I'm a: Knowledge Seeker
Default Re: DFI-ITOX G4S600-B with Chemicon KZGs - compatible caps?
Quote:
Originally Posted by mockingbird View Post
Nice job! Any reason you chose not to replace the 5 or so 6.3mm OST caps, most of them near the northbridge?
As far as I know, only the KZGs are known problem causers. I only replaced those. Are there issues with the OST caps too?
jesscat606 is offline   Reply With Quote
Old 04-23-2015, 09:41 PM   #22
c_hegge
c_hegge's Avatar
City & State: North Coast, NSW
My Country: Australia
Line Voltage: 240V 50Hz
I'm a: Professional Tech
The small 6mm ones aren't usually under a lot of stress, and so they may not be a problem, but OST aren't a reliable brand. The Nichicon HMs may also be a problem if they are older than 2005. The date codes are usually something like H0324 or A0324 (which would mean 2003, Week 24)
__________________
c_hegge is offline   Reply With Quote
Old 04-24-2015, 11:43 AM   #23
jesscat606
My Country: USA
Cool Re: DFI-ITOX G4S600-B with Chemicon KZGs - compatible caps?
Quote:
Originally Posted by c_hegge View Post
Looks good! The caps all look like they are installed correctly. Fire it up and see how it goes.
Looks good. Voltages booted up pretty close:
+1.5 = 1.5
+3.3 = 3.39
+5.0 = 5.18
+12.0= 12.09
-12.0 = -12.28
5VSB =5.06
I'll let it run for a while on the test bench - any other burn-in procedures I need to know about?
Old 04-24-2015, 11:50 AM   #24
jesscat606
My Country: USA
The Nichi's are all 06's.
Old 04-27-2015, 03:22 AM   #25
Bungz
City & State: UK
My Country: UK
Looks good.
But just so you know the outside of anti static bags can be conductive.
Bungz is offline   Reply With Quote
Old 04-27-2015, 04:54 AM   #26
c_hegge
c_hegge's Avatar
I didn't pick up on that on the picture, but yes, it is true. Don't test stuff on Anti-static bags or foam. I usually use a motherboard box for that.
EDIT: 5200RPM? That CPU fan must sound like a jet engine.
Old 04-27-2015, 06:46 AM   #27
kc8adu
kc8adu's Avatar
City & State: dayton ohio
My Country: U.S.A!
Line Voltage: 12vdc,120/240vac,480vac 3ph on my bench
i fix a lot of those and the worst complication is a vrm fet failure that sometimes totals the board.
if it posts its fine.
as for the fan who cares.it needs all the help it can get in an exporter.
slap it together and put it back on the air.
rebuild the power supply as an "oh shit" spare.
i use panasonic fm in those.
its just a fsp with a connector added custom.
kc8adu is offline   Reply With Quote
Old 04-27-2015, 09:42 AM   #28
jesscat606
My Country: USA
haha yeah, that fan is pretty loud. And also, that's the inside of the bag.
Thanks, guys, for all your help! I doubt I'd have attempted this without your advice!
Old 05-30-2019, 11:44 AM   #29
jesscat606
My Country: USA
Followup: this board was still running happily when it was retired recently. For aynyone else needing it, here is what I used.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2019
Powered by vBulletin ®
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
