toshiba sat dablidmb8e0 rev e schematic
    need schematic toshiba satellite main DABLIDMB8E0 rev e
    cpu intel i5 4th gen kbc nuvoton , bios U18 GD25B64BISIG
    Re: toshiba sat dablidmb8e0 rev e schematic
    https://www.badcaps.net/forum/showth...ht=DABLIDMB8E0
      thanks, but it doesn't match
        The schematic isn`t available, the blbd is the closest schematic there is. There are some differences,for those parts you need to find the datasheets and/or another schematic with those parts.
        1. BLID have KBC NPCE985LA0DX, charger ISL88732
        2. BLBD have kbc NPCE791LA0DX , charger ISL88731
          ok thanks, can you tell me where the rtc battery is located, why don't i see it?
            On some boards there is no battery,the RTC section is powered by the main battery
              ah that's why, in fact, I could not find it, so if I remove the main battery it is as if I removed the rtc battery
                ok
                  Toshiba satellite main DABLIDMB8E0 rev e
                  No dispaly any one can help me please
                    Good afternoon, someone can I have an equivalent for this component
                    r025
                    9661-25
                    it is from a toshiba dablidmb8e0 rev: e
                    on the plate it says pu802
                    Thanks in advance
                      r025
                      9661-25
                      Thanks in advance
                      GMT G9661-25
                      https://cdn.badcaps-static.com/pdfs/...4e45c48d2c.pdf
                        Originally posted by smdflea View Post
                        I'M NEW TO THIS EVEN THOUGH I LIKE IT AND I WANT TO LEARN
                        Thank you very much, thank you, you can decide on an equivalent that I do not know
                          Sure.Check the datasheets to make sure the replacement part has the same number of pins,the same size,same voltage ratings,same pinout ,same characteristics.
                          Linear Regulator NMOS Series GS2231 RT9018/RT9042/RT9059 up0104/up7704 G9661/966A APL5920/APL5932 AX6613/AX6614 AME8846 GS7105/GS7133
                            thank you
                              SMDFlea can you help me, I am looking for the DATA SHEET for PU1 & PU6.
                                I don`t know what PU1 and PU6 are ,post pictures of them so we can see the marking codes
                                  I found them:PU1=5318 is G5318,PU6=813H is isl95813H.thks
