Lenovo IdeaPad 330S-15ARR - 330S_ARR_V06
    Re: Lenovo IdeaPad 330S-15ARR - 330S_ARR_V06
    Yes, for sure I learned the lesson.
    I tried to edit the DMI info using "DMI EDITOR" both under Windows and as EFI Shell, but I can't write the parameters.
    Is there any other tool that works?
    I also tried LVAR but the only version I found does not work.
      Go back and read post #29 again as I already told you, but this time very carefully.
      You don't need any tool, just a simple hex editor.
      Become a Badcaps supporter
      Thanks to all supporters.​
        The post #29 says:
        enter the original bios of the laptop
        But as i told you I don't have it. I have also managed to get a donor BIOS from another machine and I know the process explained in that post(already done by me on macbook BIOSes), the problem is that I don't know how to replace the infos I have into the block of the update extracted bios.
          The post #29 says:
          And I said take the donor DMI (which is in the donor bios of course)
          Originally posted by Vesko356 View Post
          Now your option is to take a donor DMI block and edit the information from the stickers on your machine, including the Windows key.
          ...the problem is that I don't know how to replace the infos I have into the block of the update extracted bios.
          The whole process of transferring or "replacing the infos" is described at post #29! That's why I said several times - read the post and do it.
          In short:
          1.Copy DMI block from the donor bios.
          2.Paste the donor DMI block in the bios from the Lenovo site.
          3.Edit the serial numbers in the DMI block with yours.
          4.Do the same with the Windows key.
          Done.
            Thank you, now I have all the infos.
            The question is the point 3:
            Can they be edited directly in the HEX file using HEXD?
              Yes.
                Thank you, I will try!
                  Lenovo HSB J MV-6 94v-0 E89382 -- 330S_ARR_V06 ---REVV:MP ---- BIOS DUMP PLEASE
                  i attach the old bios bile, the problem that I have is "no display", internal or external.
                  everyting working fine on the board, no heat, all power suplays have voltage, CPU ryzen 5 with internal graphic card, have 0.95 V but still no display
                  please help me with bios file, I appreciate
                    Re: Lenovo HSB J MV-6 94v-0 E89382 -- 330S_ARR_V06 ---REVV:MP ---- BIOS DUMP PLEASE
                    this bios is working for me
                    problem solved
                      mybe someone have shema for this board? pleaseee
                        Schematic Requests ONLY! : https://www.badcaps.net/forum/forumdisplay.php?f=41
                          I have this exact model which out of the blue stopped POSTing. And while I'm somewhat tech-savy I had no idea how to debug my sudden-brick.
                          I (correctly) assumed it was somewhat related to the BIOS-chip and while it was a steep learning curve i was able to dump, insert my keys and reflash a working BIOS - mainly made possible by this thread.
                          So I wanted to say a big THANK YOU to the gurus! You rock!
                          I'm totally hooked to the topic now. Out of curiosity I was even able to locate, extract and change the boot logo. This is so awesome.
                            hello, can some one help me?
                            yesterday, my lenovo stops starting. When i power up, fan is working , at the begin with low speed, 7-8 sec speed is a little higher. But i have no display, black screen.
                            how to know if it is bios which is corrupted or some thing else?
                            i have CH341 but if it is usefull...
                            thanks
                              Hi Sir Peste... our guide Helps me A lot. do you teach how to edit various bios Bin? thank you..
                                Originally posted by peste View Post
                                you need the HxD program (you can find it for free on the internet), enter the original bios of the laptop and the bios extracted from the update on the site in the program, click on the original bios, top left "search", "find", in the top box "lenovo "(search for lenovo), in the box below it remains (text-string) and check 'all' and press ok ... The DMI information is in the region 1EE000 - 1EE22F, so the length of 230, select this region by left click on mouse and going down, then right click and copy. Now click on the bios extracted from the update and search for the same region in this bios (go directly to 1EE000), select the same region (1EE000 - 1EE22F), right click on the mouse and (paste insert). ready with DMI information. For (key windows) the same procedure but the region is 330250 - 330280 so length 40 ..
                                I hope this helps ..
                                Hi Sir Peste... your guide help me a lot. can you edit various bios Bin Sir do you have class for it thank you
                                  Originally posted by mahmoodjavan View Post
                                  BIOS
                                  7wcn30ww.bin
                                  330S_ARR_V06
                                  Works fine. txk!
                                    Lenovo Ideapad 330S-15ARR Bios Request
                                    Hi There,
                                    I would like to request a bios rebuild of the attached bios, the main board model number is 330S_ARR_VO6 REV MP
                                    Laptop doesnt display after a bios update attempt.
                                    If possible i would like to retain the dmi info
                                    Model Name : 81FB
                                    MO : YDN0B8616023
                                    MTM : 81FB004XUK
                                    SN : YD04QYSN
                                    Thank you
                                      Re: Lenovo Ideapad 330s Bios Request
                                      Originally posted by ScorpioMan86 View Post
                                      Hi There,
                                      Thank you
                                      Post the laptop serial number
                                        Apologies, i have updated the original post with the info
                                          Try the bios at post #27. If you can use a hex editor read post #29 ,copy your DMI using the off-sets from your backup to the new bios. If you can`t do it let us know
