looking cv501 la-e891p rev 3.0 bios
    Anyone have dump bios for this model
    Acer A315-53-317L
    MB : C5V01 LA-E891P Rev 3.0
    2018-09-14
    Thank you
    Re: Acer A315-53-317L
    Acer A315-53-317L
    2018-09-14
    Thank you
    post the original bios
      working bios extract from acer website
        guys, can some one give me a clean bios of cv501 la-e891p rev 3.0?
        Model acer 3 a315-53
        Cant upload the old bin because it says invalid file
        thanks in advance
          Re: looking cv501 la-e891p rev 3.0 bios
          Post your backup & model number
            I can't upload my old bin. Keep on saying invalid file.
              give me your serial number
                i got 2 in my collection try and chek which one work for you
                  What model is your bios programmer .
                    i am using ch341a programmer.
                    at 1st the laptop is working but when i reprogram the bios with this programmer. it keep on saying chip with the contents are not the same even when i put the old dump. is my programmer bad? because i have been using this with winbond and it was doing good but with this chip xcm, i think its not working. my problem is that when i use
                      thanks but its not working for me.
                        at 1st the laptop is working but when i reprogram the bios with this programmer. it keep on saying buffer is not the same even when i put the old dump. is my programmer bad? because i have been using this with winbond and it was doing good but with this chip xcm, i think its not working.
                        There is some alternative better software you can use with the CH341A .NeoProgrammer ,AsProgrammer ,Colibri .You`ll find them all on the forum if you search. Always make 2 backups and verify they are both the same using a hex editors file compare function . HxD - https://mh-nexus.de/en/hxd/ .
                        Post your original bios backup.
                          here
                            here
                            so finally you successfully make a backup dump ?
                            is it original backup ?
                            than send me laptop your serial number
                              thats the originaL backup. but why its not working when i put it back.
                              NXH9KSP00190400813400 S/N
                                maybe dump is not backup properly because of your programmer tool or its software
                                Follow the post #9 and try again
                                  i already did and it is giving me so many differences.
                                    is my dump ok sir?
                                      is my dump ok sir?
                                        Maybe the bios chip is the one that is faulty.
