Esprimo Q9000
    Esprimo Q9000
    actually, it is a desktop but with laptop motherboard.
    the cpu is getting hot but no display:
    5v, 3.3v 1.08v are present when off mode with ac on
    here are the pictures:
    i already changed ram with no success
    Re: Esprimo Q9000
    try another CPU that's the 1st generation so maybe you get lucky.
      Re: Esprimo Q9000
      i changed the cpu but still very hot with no display
        Re: Esprimo Q9000
        you saw the CPu tested working in another unit?
          Re: Esprimo Q9000
          the cpu is core i3. i tested instead core i5, but still not working. i am going to test the cpu on other board
            Re: Esprimo Q9000
            maybe they are not compatible or the cpu its not good.
            seen them go bad
              Re: Esprimo Q9000
              seen them go bad
              i tested the cpu on other laptop and it is great
              shall i reflow a chip??
                Re: Esprimo Q9000
                seen them go bad
                note: i tried to flash the bios but i have a problem with the bios file:
                when i read the eprom it is 25q64 and the file i saved is 8mb but the bios on the site of the board is 2mb.
                  Re: Esprimo Q9000
                  I have the same pc, sometimes it starts and sometimes it does nothing at all, as if there was no power.
