HP EliteDesk 800 G2 Small Form Factor PC bios request
    Re: HP EliteDesk 800 G2 Small Form Factor PC bios request
    Originally posted by alexdc View Post
    They are exactly the first 2 that you mentioned. I am having a hard time flashing the 8mb with my clip. I need a better clip.
    Those clips are shit,thats maybe why you didn`t get a good bios read the first time.Desoldering is the best way,then use an adapter. I don`t know much about the programmer you`re using either.Most members here buy the CH341A ,its not a bad programmer if used with alternative software.
    If you havn`t got a hot-air station then you can still desolder the chips using a temperature controlled soldering iron,if you have one .
      hp 800 g2 clear me
      hi in clear me hp 800 g2 sff
        Can anyone recover this corrupted bios.
        obrigado
          obrigado
          try post#2..
            Originally posted by peste View Post
            try..
            hi everyone
            the files you added this post are corrupted and cant unzipp
              Originally posted by mojtabarecovery View Post
              hi everyone
              Update winrar,or use 7-zip
                try post#2..
                I already tried, but it doesn't work
                any other suggestion. in my case i lost my pc when trying to update the bios.
                gives a BIOS restore error and does not exit.
                obrigado pela ajuda
                  obrigado pela ajuda
                  HP EliteDesk 800 G2
                  Become a Badcaps supporter
                  Thanks to all supporters.
                    Just wanted to say thank you all for providing such great source of information and fw binary.
                    Using the files provided in hoaca388's archive file, I was able to recover from the DXE error following a HP fw upgrade process that has corrupted the bios + ec.
                    The PC seems to behave normally. The model TAG and serial number have been kept and not overwritten.
                    Thanks again, cheers!
                      hp elitedesk 800 g2 sff bios needed
                      hi every one
                      my bios file is corrupted
                      i need this model hp bios bin file
                      my bios file is included too.
                      thanks every one for response.
                        Re: hp elitedesk 800 g2 sff bios needed
                        hi every one
                        try post#2..
                          try post#2..
                          thanks so much for your help peste
                            Hi guys can you help me remove the password of this bios. thanks in advance
                              Here
                                thanks sir hoaca388. i'l update you later if the bios is good. god bless
                                  Hi... pls help hp elitedesk 800 g2 sff unlock
                                    try..
                                      thank you so much sir peste for the help...
                                        Need bios repair
                                        s.no 2UA641268H
                                        Product no L1g76av
                                          Originally posted by OKRPKCOMP View Post
                                          Need bios repair
                                          s.no 2UA641268H
                                          Product no L1g76av
                                          HP EliteDesk 800 G2 Base Model Small Form Factor PC
